Hello everyone.
Sorry for the long-winded post, but I'd like to connect my new Asus monitor to both a gaming laptop and a desktop PC but am a bit confused as to which cables I should use.
The new monitor has one DisplayPort 1.2 port and two HDMI ports.
The laptop only has a single HDMI port, while the desktop has both HDMI ports and a DisplayPort.
The desktop will always be connected to the monitor for daily personal use, while the laptop will only get connected to the monitor for occasional gaming.
I'm confused as to which cables to use with the two different kinds of ports. Here are some possible options I see:
1) I One dedicated HDMI cable from monitor to desktop and a second HDMI cable from monitor to the laptop.
2) DisplayPort cable (both ends) from monitor to desktop and HDMI cable from monitor to laptop.
Are there any other options to consider? Would I want to run a cable with DisplayPort connector at one end (monitor) and HDMI connector at the other end to the laptop for best display performance?
Appreciate any input on how to proceed.
Help with connecting new monitor to laptop and PC
LoganR
Boomchakadah
Re: Help with connecting new monitor to laptop and PC
option #2
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
Dalek
Option 2, but what refresh rate does your monitor have? some displays will work up to 144hz with HDMI and 240hz and above with DisplayPort.
