All 3 regs are correct.
I found why, for whatever reason, maybe driver related, it required you to have run the RW GUI version at least once after the reboot from the REG changes.
I added a workaround that should do it automatically, you can try redownload the script. Be sure to keep it at the correct folder as instructed.
If it doesnt work, you can try opening the RW.exe from the tools folder once and closing it, it should be enough to work.
