Rare/Electrical Issues Affecting Latency — Interference, EMI, EMF
Sqnax17
Re: Rare/Electrical Issues Affecting Latency — Interference, EMI, EMF
Post by Sqnax17 » 25 Apr 2023, 21:22
Sqnax17 wrote:
25 Apr 2023, 20:58
Sqnax17 wrote:
16 Mar 2023, 16:33
Hi guys, I'm from Brazil. I am not encouraging anyone to stop looking for solutions. I'm a layman on the subject, but I've been researching this anomolo inputlag caused by electricity for years. in 2018-2019 the pc was perfect and very cool, but after 2019 it's all over. I tried 2 completely different pcs, different houses and nothing happened. Recently, after testing an online double conversion UPS with pure sine wave (I feel the battery play better with the equipment disconnected from the socket, but it doesn't come close to normal operation) it didn't work, not even a panamax power conditioner. I saw several people saying that a balanced theroidal transformer would solve the problem, so I decided to buy it and spent some money because I live in Brazil and for us it is a very high value. And it didn't solve anything. So guys, don't spend money for nothing until you have an explanation with factual evidence about the solution. I particularly give up playing for fun and competitively (which I did best and it was good). It really is impossible.
Interesting updates guys, recently in my neighborhood a transformer shorted out and with that burned some equipment in some houses. the electric company changed it for a new one, and guess what, it improved a lot, but what is more interesting is that when i turn on the electric shower the iputlag disappears completely, the iron too but reduces it just a little. what they tell me. Soon I will call an electrician to measure everything and give me an opinion.
Yes, if your home's electrical installation is inadequate, it is possible that the electrical wires are undersized in relation to the electrical load demanded by the equipment in your home. When this happens, a voltage drop in the electrical network can occur, which can affect the performance of electrical equipment and, in some cases, cause permanent damage to it.
well-crafted question in gpt chat yielded me a possible discovery, in a few days I'll be back with updates
cybepine
Post by cybepine » 26 Apr 2023, 00:39
Sqnax17 wrote:
25 Apr 2023, 21:22
Sqnax17 wrote:
25 Apr 2023, 20:58
Sqnax17 wrote:
16 Mar 2023, 16:33
Yes, true. Ask the electrician to check, that there is no any current on water pipes (below 30mA) or constant current on ground line.
Please let us know the reason for it (input lag), when you can.
Do you know what is your earthing system? TN-C, TT...?
Sqnax17
Post by Sqnax17 » 26 Apr 2023, 21:57
cybepine wrote:
26 Apr 2023, 00:39
TT
finalboss
Post by finalboss » 06 Jul 2023, 17:38
Sqnax17 wrote:
25 Apr 2023, 21:22
Still waiting you back my friend, Im from Brazil too, Is there a way to get in contact w you? Maybe discord? Steam?
https://steamcommunity.com/id/internetdeus
Sqnax17
Post by Sqnax17 » 14 Jul 2023, 21:25
finalboss wrote:
06 Jul 2023, 17:38
Sqnax17 wrote:
25 Apr 2023, 21:22
meu discord, RyanLINDO22#3305
TomerA
Post by TomerA » 22 Jul 2023, 07:04
F1zus wrote:
19 Mar 2023, 18:10
Online UPS really reduces the input lag. Many professional players use it. I bought myself an online UPS a few months ago and it removed the input lag by 90%.
If online UPS does not help you, then it is not about electricity. So you have a high level of emi or something else.
Which Online UPS are you using?
F1zus
Post by F1zus » 24 Jul 2023, 17:40
TomerA wrote:
22 Jul 2023, 07:04
F1zus wrote:
19 Mar 2023, 18:10
I am using shtyl online ups. This is not the best model in terms of filtering, but it can significantly reduce the input lag. Yes, the difference in mouse sensitivity between day and night remains, but not as big as before.
Sqnax17
Post by Sqnax17 » 30 Jul 2023, 07:30
Sqnax17 wrote:
16 Mar 2023, 16:33
I have updates friends
I recently bought a complete off grid photovoltaic system and I'm waiting for it to arrive to do the assembly. a system that generates 1200w of power. I will be generating my own energy, excluding all factors that cause problems with electricity. I did that because I bought an isolation transformer and it improved the inputlag but it didn't solve it and I decided to buy these solar systems. I'm confident, I'll be back soon with updates after testing. Hugs
bad English
InputLagger
Post by InputLagger » 30 Jul 2023, 19:31
Sqnax17 wrote:
30 Jul 2023, 07:30
Sqnax17 wrote:
16 Mar 2023, 16:33
bad English
Super, good luck 🍀 We're be waiting here, for results from you! 👍
Sqnax17
Post by Sqnax17 » 13 Aug 2023, 13:40
Sqnax17 wrote:
30 Jul 2023, 07:30
Sqnax17 wrote:
16 Mar 2023, 16:33
bad English
Eu desisto
Eu só vim para dar-lhe as atualizações.
Estou fora da rede e produzindo o meu próprio com excelentes equipamentos. Não resolveu o problema, apenas melhorou. O monitor continua horrível (165hz 1 ms) não consigo ver nada, não consigo entender o jogo, e muito desync e inputlag. A energia solar fora da rede melhorou a capacidade de resposta em cerca de 20%, portanto, esse paradigma de que a eletricidade causa inputlag é uma mentira. porque ainda assim, quando desligo e ligo o monitor, o inputlag desaparece e a qualidade do monitor é extremamente boa, porém dura apenas 4 segundos exatos e degrada. Eu queria xingar agora...
Pessoal desista, Deus não queria que a gente se divertisse brincando. Eu nunca vou descobrir o problema. quem é pro player hoje já nasceu iluminado. Já troquei o pc duas vezes, aterramento, bios, configurações no windows, windows, periféricos, cabos de fibra hdmi, nobreak, condicionador de energia, transformador teroidal, transformador isolador e por fim energia solar off grid e não ficou bom. Quem disse que jogou fora do grid foi rápido porque houve uma melhora, mas não 100%. Então, talvez alguém tenha concluído que corrigiu 100%, mas não. Desisto. Se quiser fechar o tópico.
