I dont have grounding , interference has 2 option on-air / from cables , grounded shielding(pc case vs) will filter on-air interference.Sqnax17 wrote: ↑23 Aug 2023, 21:24to be talking about grounding, yours must have fixed the problem? If this statement has no basisamorou wrote: ↑23 Aug 2023, 17:22You prolly have bad grounding , try disabling it if you cant redone itSqnax17 wrote: ↑22 Aug 2023, 13:58unfortunately guys, playing in solar offgrid does not fully solve the problem, only partially. And connect the pc directly to the battery as well. But if someone is looking for a small improvement, throwing off the grid helps the problem, but it doesn't solve it 100%. There is still the problem of turning off and on the monitor, after returning it is perfect for 4 seconds and then degrades. How resetting the monitor power would make everything work perfectly but only for a few seconds. I really give up trying to find a solution. But I will follow up on this issue. This problem is very complicated but I know that resetting the power supply monitor totally fixed the problem for a few seconds so the problem is related to this power resetSqnax17 wrote: ↑16 Mar 2023, 16:33Hi guys, I'm from Brazil. I am not encouraging anyone to stop looking for solutions. I'm a layman on the subject, but I've been researching this anomolo inputlag caused by electricity for years. in 2018-2019 the pc was perfect and very cool, but after 2019 it's all over. I tried 2 completely different pcs, different houses and nothing happened. Recently, after testing an online double conversion UPS with pure sine wave (I feel the battery play better with the equipment disconnected from the socket, but it doesn't come close to normal operation) it didn't work, not even a panamax power conditioner. I saw several people saying that a balanced theroidal transformer would solve the problem, so I decided to buy it and spent some money because I live in Brazil and for us it is a very high value. And it didn't solve anything. So guys, don't spend money for nothing until you have an explanation with factual evidence about the solution. I particularly give up playing for fun and competitively (which I did best and it was good). It really is impossible.
(Good grounding will help isolation from on air interference , if you have bad ground , ground cable itself cant act as +antenna for system)
Since going off-grid didnt work for you I recommended it
