BENQ or Asus gaming monitors...or Acer and AOC
Josu
Post by Josu » 30 Aug 2014, 20:51
I dont have a good english, so i have problems to understeand reviews
can you help me choose good monitor with 120 HZ
Now looking at Acer Predator GN246HLBBID , 150 pounds at overclockers uk
Or i need pay more for BENQ or Asus models?
Usually i playing World of Tanks, Diablo 3 and watching moovies and surf at internet
I have asus gtx 670 direct cu II graphics, 4670k processor
Thank you for understanding
Josu
Re: BENQ or Asus gaming monitors...or Acer and AOC
Post by Josu » 31 Aug 2014, 09:19
everybody watching, but dont give any advice :(
Black Octagon
Post by Black Octagon » 31 Aug 2014, 09:45
How much are you looking to spend? Do you just want 120Hz or also low blur technologies?
Sent from dumphone (pls. excuse typos and dumbness)
Josu
Post by Josu » 31 Aug 2014, 15:10
Max 500 pounds, i dont wanna ROG because i need change my graphics aswell
Q83Ia7ta
Post by Q83Ia7ta » 31 Aug 2014, 21:16
Pay more for BenQ or Asus models. XL2411Z, VG248QE, XL2411T are cheap in some regions. Acer Predator GN246HLBBID is a bit worse than this models i guess. For example it has very aggressive overdrive and it can't be disabled.
Josu
Post by Josu » 01 Sep 2014, 18:37
Maybe go for Asus ROG monitor, or gtx 670 not enough for my games?
Josu
Post by Josu » 01 Sep 2014, 19:32
Or go to BenQ XL2720Z
Edmond
Post by Edmond » 04 Sep 2014, 04:19
Pick one of these and you WILL have a good time.
http://www.overclockers.co.uk/productli ... &catid=948
You should NOT buy anything else that is not a gsync monitor.
Also, your video card is good enough for any of those.
Except the 4k one will force you to play the newest games on low, and the games you mentioned on medium around60fps, but that clarity will be sick and ull feel like ur playing diablo4 and WOT2.
Also the 4k one is 60hz and doesnt have ULMB(lightboost2 - which i dont recommend if your using just one video card anyway).
If you havent had a 100hz+ monitor before, i think the 4k might be incredibly enjoyable and its right in your budget.
If you are used to 100hz+ monitors and/or plan on using ULMB... you might want to get the 27" acer, or 24" AOC.
Fuck the ROG swift, its too expensive. It is good if you have the money to burn, just be aware that it is HEAVILY overpriced, but it is the first of its kind.
kilos
Post by kilos » 04 Sep 2014, 05:22
Buy benq xl z series if u like severe ghosting!
