Serious problem with custom resolution vt trick
MangstaH
Post by MangstaH » 05 Sep 2014, 16:18
i have enabled OS on, I have tried differend setups, even cru and patching nvidia toasty thing. SAd thing is it worked before i resetet my Benq2027z settings to default, after that i havent got my 1350 setup working again. Any helps please? :)
Re: Serious problem with custom resolution vt trick
Post by Chief Blur Buster » 14 Sep 2014, 16:02
MangstaH wrote:i have enabled OS on, I have tried differend setups, even cru and patching nvidia toasty thing. SAd thing is it worked before i resetet my Benq2027z settings to default, after that i havent got my 1350 setup working again. Any helps please? :)
Can you tell me if you used the ToastyX method or the NVIDIA Control Panel method?
It may have stopped working when you upgraded the graphics drivers.
Dotclock might be beyond graphics driver range, so to fix this, try:
- Using ToastyX Pixel Clock Patcher from http://www.monitortests.com
- Or try using a Horizontal Total of 2040, when you do Vertical Total 1350
