jorimt wrote: ↑12 Oct 2023, 09:03You can try disabling MPO, but it may cause more issues than not depending on your setup.Akso wrote: ↑12 Oct 2023, 03:56I remember that before having my multi-monitor setup, Ive played a bit with only the Asus one plugged in. It was smooth and working great. Is MPO the culprit or maybe the Nvidia Inspector thingy with the Multi-compatible/Single-compatible monitor setting in G-SYNC ?
Did you know which settings to setup for multi-monitor maybe ?
As for the multi-monitor settings in NVI, it shouldn't make a difference what it's set to if you only have the ASUS plugged into the GPU.
Due to the near instantaneous pixel response times of OLED, lower framerate judder due to sample-and-hold persistence can be more apparent on OLED than LCD, and the lower the framerate, the more apparent it is.
So mix that with what I explained previously, and it certainly won't help. I.E. a superior display can reveal content limitations not previously seen.
After trying a lot of things (1 or 2 monitor plugged in, MPO disabled, different G-sync disabled etc...), 140-160 FPS feels still choppy. Maybe its CPU related, I have a 12900k ? Feel desperate at this point
