I got a new pc that no longer allowed me to use Scewin. Scewin actually helps A lot too .. but it’s not the fix like I stated the infection could come back in the quote lol. But non the less I can play normally againMIETAS wrote: ↑23 Oct 2023, 13:27Aren't you the guy that has fixed his "input lag" before?texre wrote: ↑22 Oct 2023, 00:57This will most likely be my last post here.. I have 100% fixed my problem some how by getting a air purifier, I’m not gonna suggest buying one because everybody problem is different I live in a very dusty place so that can be my only logical reason as why it helped. But my game has never felt this good since I’ve moved here 4 years ago even with solor gen nothing has came close. the clarity I have on my monitor is crystal clean my mouse movement my hit detection everything every game every day a
viewtopic.php?f=24&t=11847&p=92562#p92562
see you soon![]()
2 words
Re: 2 words
Re: 2 words
is anyone planning to buy this? need more confirmation that it really works.
Re: 2 words
That sucks. Still works for me so good luck to the rest of you I finally can never look up this dreaded forum again cheers
internetexplorer4
Re: 2 words
can you record a video doing like an aim trainer with air purifier and without? for us to see the difference
please that would be very useful for the topic
Re: 2 words
texre, is it still working fine til this day? please give an updatetexre wrote: ↑24 Oct 2023, 21:59I got a new pc that no longer allowed me to use Scewin. Scewin actually helps A lot too .. but it’s not the fix like I stated the infection could come back in the quote lol. But non the less I can play normally againMIETAS wrote: ↑23 Oct 2023, 13:27Aren't you the guy that has fixed his "input lag" before?texre wrote: ↑22 Oct 2023, 00:57This will most likely be my last post here.. I have 100% fixed my problem some how by getting a air purifier, I’m not gonna suggest buying one because everybody problem is different I live in a very dusty place so that can be my only logical reason as why it helped. But my game has never felt this good since I’ve moved here 4 years ago even with solor gen nothing has came close. the clarity I have on my monitor is crystal clean my mouse movement my hit detection everything every game every day a
see you soon![]()
Re: 2 words
I bought the levoit core200s and it didn't work. Maybe he got a different model that does something different or maybe his issue is different to mine
Re: 2 words
If air purifier helped him , its not because of purifiering procces , its circut of the device causing something
Humidty effects static electricty build-up , yet it will not impact the "issue"
You guys asking wrong questions
Re: 2 words
im willing to try everything, the purifier cleans static electricity in the air which may be the fix for alot of people.. i have input delay that started on xbox first then bought a pc and have same problem on there. also it could be a specific model of air purifier that does the trick, all op said was levoit alexa air purifier, needs to be more specific theres so many smart ones
Re: 2 words
Did you read thisJurr wrote: ↑23 Nov 2023, 08:23im willing to try everything, the purifier cleans static electricity in the air which may be the fix for alot of people.. i have input delay that started on xbox first then bought a pc and have same problem on there. also it could be a specific model of air purifier that does the trick, all op said was levoit alexa air purifier, needs to be more specific theres so many smart ones
viewtopic.php?f=24&t=12655
