ASUS ROG Swift 500Hz Announced!
SirensOW
Re: ASUS ROG Swift 500Hz Announced!
Post by SirensOW » 16 Dec 2023, 21:47
babooz99 wrote:
10 Dec 2023, 19:28
Stop complaining about a dead pixel or pressure spots or colors issues. You paid 900 for one thing and one thing, the 540hz refresh rate. Does the refresh rate work? Yes? Then the monitor is doing it's job. Stop being karens
Just because I paid a premium for a one-of-a-kind feature doesn't excuse ANY manufacturer from QC issues, sorry. I'm returning my monitor.
gab848
Post by gab848 » 17 Dec 2023, 01:52
kameCS wrote:
15 Dec 2023, 10:31
my opinion on the pg248qp, Asus undoubtedly offers better image clarity but it is not perfect, it really lacks an option to adjust the sharpness, the screen coating seems of average quality, it is quite visible to distinguish lots of small shiny spots which makes the image muddled (eTN technology defect or asus coating?), the ulmb 2.0 is more of a marketing gimmick and causes more image problems, personally I I found the overall use disappointing compared to aw2524hf, I do not recommend it and I expect better from this panel which will equip the next Acer XV242F and Zowie XL2586X
Edit, can't disclose this information.
daviddave1
Post by daviddave1 » 17 Dec 2023, 05:58
daviddave1 wrote:
16 Dec 2023, 09:30
kameCS wrote:
16 Dec 2023, 02:19
masneb wrote:
16 Dec 2023, 00:05
Weird, I found ULMB to be superb and honestly the non-ULMB mode to be lackluster by comparison. You can easily see this playing something like OW2.
Also most places regard the Aw2524hf as awful as it's essentially a IPS panel that was originally meshed with 360hz that was slapped with 500hz.
we all agree that currently IPS technology has reached its limits in terms of clarity at high speed, however at low and medium speed the rendering is excellent
I have just made 2 videos :
aw2524hf ghosting test speed 720px/s
https://www.youtube.com/watch?v=jU8Yh_HI5Dw
aw2524hf frame rate test speed 720px/s
https://youtu.be/-Kv3Z9b3sGI?si=P03Y2tsXTCTyxK0s
this new e-tn panel is incredible, after calibration the colors are superb (thank you tftcentral for excellent icc profile), however all its qualities are diminished by this shiny parasitic veil which makes its image less sharp and messy, to have the 2 monitors I clearly prefer the precision of the aw2524hf which does not suffer from this parasitic coating on the screen and and has an excellent sharpness option
I really hope that this major defect is not caused by liquid crystal pixel technology
Just made a tft patreon account after reading your post. installed the icc profile. its very nice idd ty.
The TFTCentral ICC profile makes a Huge difference.
Cause u need a Patreon account to download it I uploaded it just now
https://we.tl/t-g6UrAw3zM6
From the downloadpage of tftcentral also the following info:
Preset mode: Racing
Notes incl. Gamma: Gamma 2.4. Gamut wide
Brightness: 20
Contrast: 50
R:100
G:100
B: 98
( I changed the settings to gamma 2.2 and played with the colors some more. But its a good start.)
| Now: ASUS PG248QP 540Hz. | Past : VG259QM with the Qisda panel/PG27AQN/XL2566K
babooz99
Post by babooz99 » 17 Dec 2023, 21:55
SirensOW wrote:
16 Dec 2023, 21:47
babooz99 wrote:
10 Dec 2023, 19:28
Stop the cap
CYCLOPSAG
Post by CYCLOPSAG » 18 Dec 2023, 01:21
If im unable to hit 540fps on some game titles, should i still keep my PG248QP monitor refresh rate at 540hz? or lower it to around the same FPS im getting?
how do i eliminate tearing while still not adding extra latency?
Boop
Post by Boop » 18 Dec 2023, 02:06
CYCLOPSAG wrote:
18 Dec 2023, 01:21
Leave it on 540hz and/or turn on G-Sync. If you want to use ULMB, the lowest refresh rate you can go to is 360Hz when it's activated.
daviddave1
Post by daviddave1 » 18 Dec 2023, 02:19
CYCLOPSAG wrote:
18 Dec 2023, 01:21
Just keep it at 540 with ulmb2 on. It's kinda a myth that a image will tear of the rails if hz and fps does not match. ( Also in a ASUS USA stream Asus Usa also mentioned that the GSYNC module in this monitor also works to a degree withouth GSYNC enabled to keep the frames in sync. I can link the yt stream later if u like)
Same goes with ulmb2 . Ulmb2 still kicks in even if the hz don't match with the fps. Maybe not 100% optimal. But it's definitely there. You dont wanna miss out on the insane low inputlag this monitor provides.
forcedreg
Post by forcedreg » 18 Dec 2023, 05:57
gab848 wrote:
17 Dec 2023, 01:52
You'll still need the newest version of Windows 11 23H2
I would run it at 500 hz in W10, extra 40 Hz is not worth the disadvantages of W11 in my opinion. I wonder if Microsoft considers fixing it for W10 when these monitors get more popular.
evmadic
Post by evmadic » 18 Dec 2023, 12:32
forcedreg wrote:
18 Dec 2023, 05:57
gab848 wrote:
17 Dec 2023, 01:52
Any idea if the monitor offers a 500hz option or would we need to use CRU?
5800x3d, RTX 4070 ti, Acer Nitro XV252QF 390Hz
https://www.twitch.tv/evmadic
Inco^
Post by Inco^ » 18 Dec 2023, 14:54
evmadic wrote:
18 Dec 2023, 12:32
forcedreg wrote:
18 Dec 2023, 05:57
gab848 wrote:
17 Dec 2023, 01:52
It does offer 500 Hz.
540 Hz, 500 Hz, 480 Hz, 240 Hz, 120 Hz, 60 Hz are options in NVCP.
PG248QP - XL2566K - XV252Q F - PG259QN - XL2546K - Y27gq-25 - AG251FZ - LaCie Electron 22 Blue IV
