Good FPS player admits he has hitreg andvantage
Re: Good FPS player admits he has hitreg andvantage
Post by Slender » 05 Jun 2022, 09:06
TN_fun wrote:
05 Jun 2022, 07:21
Some are so funny. This guy writes - this is a bug in windows. in 2022. when more than enough is already known about the problem. At least there are a lot of topics here.
Windows error yes. Install Linux if it's windows. If windows error, then the problem will be everywhere, right? Are you have broken of timers or what? Put Linux, play with bots, play the usual mm, the problem will be there. do it and don't write nonsense.
Why is it easier for you to believe in some stupid windows error (which no one in a normal place has) Than the fact that your equipment is malfunctioning due to interference, even at the moment of switching on, or it’s your reboot (when consumption higher), etc. .d.
this is so funny that you are talking about windows errors
ok, tell me what is that problem.
just let's not make assumptions, answer me, specifically what the problem is?
TN_fun
Post by TN_fun » 05 Jun 2022, 10:56
Go here
viewforum.php?f=24
Exactly what it is, perhaps we will find out in 20 years. When it spreads to all computers (due to the problem that is on the link above)
Post by Slender » 05 Jun 2022, 11:45
TN_fun wrote:
05 Jun 2022, 10:56
Go here
viewforum.php?f=24
I'm asking you specifically, tell me what the problem is. You write that in 2022 "everything is already known", and that the assumption (!) about the Windows error is stupid. I'm waiting for a normal answer from you.
TN_fun
Post by TN_fun » 06 Jun 2022, 14:21
Slender wrote:
06 Jun 2022, 13:29
Simple
viewtopic.php?f=5&t=8045&p=81428#p81428
that guy "broke" his windows and bios settings
I used WinTimeTester to check for any timing differences. My previous frequency was 3.22265 MHz and after the command it was something like 3.22270 or something close but still different. Furthermore I used TimerResolution tool to set my timer to 0.5 seconds
Default timer value in windows 10 - 10MHz . This guy disable hpet on bios и windows.
kokkatc
Post by kokkatc » 06 Jun 2022, 17:07
mybad wrote:
05 Jun 2022, 03:35
can you confirm Linux doesn't have a hitreg problem?
I believe the biggest benefit of using Linux over say any Window's OS newer than Windows 7 is that Linux doesn't force you to run all of your apps/games through a desktop compositor like say Windows 10 does. This is also known as DWM.
Post by Slender » 06 Jun 2022, 18:02
TN_fun wrote:
06 Jun 2022, 14:21
Slender wrote:
06 Jun 2022, 13:29
Simple
the level of your knowledge is immediately visible. are you aware that a different qpc value is used after 1803?
disable hpet in bios and windows = tsc
chel, ti ochen' tupoy, ne pishi syuda bolshe
mybad
Post by mybad » 06 Jun 2022, 18:12
Sorry, but my question didn't about the benefits of Linux.
this was a question.
Dzekson22
Post by Dzekson22 » 06 Jun 2022, 18:50
this is an internet problem in your location, i have desync in every game, sometimes 4g better than FTTH.changes in windows didnt help. I even have delays in mobile games, e.g. standoff 2 when playing on a smartphone
https://www.youtube.com/watch?v=oI5_m1vzAHM
Yagami
Post by Yagami » 06 Jun 2022, 20:15
I've been playing like this for 4 years now, hahah.
The only solution is to stop playing games...
