[Utility/Source] Successful LG overclock 144Hz to 264Hz! [LG 27GL650F Overclock Out of Range Fix]
Re: [Utility/Source] Successful LG overclock 144Hz to 264Hz! [LG 27GL650F Overclock Out of Range Fix]
Post by Chief Blur Buster » 15 Jan 2024, 20:55
ch3x wrote:
14 Jan 2024, 06:56
Additionally, though hard to confirm as I've never seen a 240hz monitor with my eyes, I don't believe the monitor is actually being overclocked to 240hz. With the scrappy program I wrote I tested overwatch running at around 300fps with the overclock at 240hz and the game was not appreciably smoother. Despite UFO test and the monitor itself in the OSD showing 240hz I find it hard to believe that I wouldn't be able to tell it was smoother.
Did you test the Frame Skipping test, that is popular among display overclockers? www.testufo.com/frameskipping
FeiNix
Re: Successful LG overclock 144Hz to 264Hz! [LG 27GL650F Overclock Out of Range Fix]
Post by FeiNix » 02 Mar 2024, 23:05
elexor wrote:
17 Jun 2022, 09:53
For a quick test you can make a simple batfile and use winddcutil
Code: Select all
:loop
winddcutil.exe setvcp 0 F9 1
timeout /t 3
winddcutil.exe setvcp 0 F9 2
timeout /t 3
goto loop
3 is seconds between commands
0 is the monitor id which is usually 0 for single monitor setups
you can use winddcutil.exe detect to list monitor ids
it worked for 1 few seconds , when i put the timeout on 0 , there is a perment fix or longer? i have LG 24GL600F and my monitor is stable at 195Hz but Out of Range is stock on my face and i cant afford higher hz monitor atm
