Difference in gameplay after purchasing power station unit
Mugabi
Re: Difference in gameplay after purchasing power station unit
Post by Mugabi » 02 Aug 2022, 19:37
[/quote]
You could try that.
And if he agrees- you should have him try your out pc too- see what he thinks.
After seeing you mention lowering ram/cpu/gpu speeds gave some smoothness temporarily- I definitely think you should give a mobo swap a try. So far, I have seen a decent amount of people have their issues fixed after replacing a wonky mobo.
[/quote]
I would definitely recommend OP to try a different mobo than the one he’s currently using as it has many usb/Bluetooth issues , probably get a stronger psu as well.
