power saving settings in windows 10
TYT
Post by TYT » 02 Aug 2022, 09:11
empleat
Re: power saving settings in windows 10
Post by empleat » 02 Aug 2022, 09:43
TYT wrote: ↑
31 Jul 2022, 10:16
how to disable CoalesecingTimerinterval open regedit type HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Power create a DWORD name it CoalesecingTimerinterval change the namber to 0
What are possible values to this, couldn't find exactly! I want to decrease timer resolution to 15.6 for power saving, but windows doesn't let me to go beyond 1ms for some reason with or without dynamic tick! It would be great, if there was program to change this in idle to 15.6 and in usage to 1ms or lower: https://randomascii.wordpress.com/2013/ ... ts-wasted/. Dynamictick can cause stuttering and is not good for muscle memory.
TYT
Post by TYT » 02 Aug 2022, 10:21
empleat
Post by empleat » 02 Aug 2022, 10:38
TYT wrote: ↑
02 Aug 2022, 10:21
high timer resolution value will not save that much power but if you want to do that use ISLC
here https://www.wagnardsoft.com/forums/viewtopic.php?t=1256 :D
It doesn't go above 1 ms. On global scale megawatts are wasted tho, but yeah main is GPU/CPU so it is in balanced mode in windows and in high perf. mode in load!!!
evmadic
Post by evmadic » 02 Aug 2022, 10:45
TYT wrote: ↑
02 Aug 2022, 09:11
part 2 after that go to program settings then Click add after that Click Browse then go to C:\Windows scroll down open explorer go to power management mode change it to prefer maximum performance do the same go to add then Browse C:\Windows\System32 then type
dwm.exe open it go to power management mode change it to prefer maximum performance your done πŸ˜„
Thanks for this!
5800x3d, RTX 4070 ti, Acer Nitro XV252QF 390Hz
https://www.twitch.tv/evmadic
empleat
Post by empleat » 02 Aug 2022, 10:59
evmadic wrote: ↑
02 Aug 2022, 10:45
TYT wrote: ↑
02 Aug 2022, 09:11
Thanks for this!
Wouldn't this cause GPU to run in highest frequency, even when idling in windows. Don't understand purpose of this, if you set a game to prefer maximum performance, it will already force GPU to run in higher P states! In windows you want it to run in like 210 mhz if you check GPU-Z, otherwise if some app will have set prefer max performance GPU will run at like 1750mhz in windows! It is annoying you have to set in Global tab "Normal" and for each App "prefer maximum performance".
TYT
Post by TYT » 02 Aug 2022, 11:55
1000WATT
Post by 1000WATT » 02 Aug 2022, 16:34
:lol:
Anonymous768119
Post by Anonymous768119 » 02 Aug 2022, 17:10
Is what you suggest with dwm.exe supported by any input lag measurements/proofs or you're just so desperate?
I think admin and mods should look deeper into your rants, because your advices and instructions can make unexpected mess in OS and decrease overall stability of your PC.
Thatweirdinputlag
Post by Thatweirdinputlag » 02 Aug 2022, 18:01
This is becoming a bit extreme, things like disabling idle state, throttling or even forcing your GPU to run on high performance when the PC is doing nothing is just too much. Even things like disabling speedstep in Bios are becoming more of a religious act rather than an actual justified need. Turning on "Game Mode" on your PC will literally force your CPU to boost into its limits without compromising intel's limitations "unless MCE is turned on". Please do your research on every feature and ask yourself whether you really need that turned off or not.
Don't get me wrong, your system can mostly handle that, when it's properly configured. Most of the people here are just lost inexperienced souls looking for answers on how their favorite game is performing differently than what they see elsewhere. Motherboard manufacturers's most of the time tend to over-volt everything to try their best in giving the end user a plug and play experience free of troubleshooting. That said, they also include all the safety features like Speedstep, thermal monitor, etc. A recipe for hardware failure will be highly probable when the end user just disables those features without knowing that his motherboard was running on intel's fail safe values shoving close to 1.5v in their CPUs.
If you are someone that has somewhat of an old rig and you are trying to squeeze every last drop of performance you can out of it, then sure, go for it! Not without doing your research though, a slow performing rig is still better than a broken one.
