Input lag issue. Creating this thread to keep you guys updated.
Cyanide_
Re: Input lag issue. Creating this thread to keep you guys updated.
Post by Cyanide_ » 24 Aug 2022, 01:19
Move to other house, just for test. Keep moving until you find a "good" house then you know it's caused by electricity and nothing else. I've seen guys, and I myself have tried like 4-5 apartments until I found a good one (my old house was surprisingly good too).
assombrosso
Post by assombrosso » 24 Aug 2022, 04:30
Iserverthefirelord wrote:
24 Aug 2022, 01:19
Oh wow 4-5 ? ? What would you recommend in a good house? Maybe far from big buildings that host a lot of people? What type of a location that has a good chance of being good for this
mybad
Post by mybad » 24 Aug 2022, 04:31
I use online ups with battery. That do not fix problem. How you can explain this?
Cyanide_
Post by Cyanide_ » 24 Aug 2022, 09:01
Fr. Tried my parents house, one apartment, friend who lives like 500m away from that apartment, other one, friend who lives 2km away from that, one more friend's house. If you have a car it's easier ofc.
If you are looking for a house/flat to test, find a house as far away as possible from your "bad" house. Because if you have bad electricity, your friend next door will have it too most likely, but a guy in other area might not have it. New, old house - doesn't really matter. It's something about local PoCo and their wiring, IMO, that's causing issues, so as long as you move out of their range it should be good.
TheKelz
Post by TheKelz » 24 Aug 2022, 12:58
24 Aug 2022, 01:19
If only that was so easy mate, I'm unable to do it right now.
Btw, FYI, just bought a different RAM kit (G.Skill) and Asus Rog Maximus XII Hero motherboard. Tested those before buying with the technician and mouse felt really good and no input lag or stutters were present. Will install it into my system now and see if it will happen on mine. I'm really starting to think it might be electricity indeed, we'll see.
EDIT: as always, MUCH better after doing some changes on my PC. Lets see if it will stay that way. Mouse and my whole PC feel sp much more responsive, but I still feel occasional mouse input lag, even though it's much better. Maybe those better VRM and power phases are helping, idk. Will keep investigating.
zurdex
Post by zurdex » 24 Aug 2022, 14:36
Before this lag started, is there anything that changed? I have the same exact problem as described so I am trying to figure out how it started rather than how to fix it in hopes of finding a solution
assombrosso
Post by assombrosso » 24 Aug 2022, 18:14
TheKelz wrote:
24 Aug 2022, 12:58
24 Aug 2022, 01:19
Those are some expensive parts, make sure they are refundable
TheKelz
Post by TheKelz » 24 Aug 2022, 18:52
assombrosso wrote:
24 Aug 2022, 18:14
TheKelz wrote:
24 Aug 2022, 12:58
24 Aug 2022, 01:19
They are, fortunately.
Anyways, input lag and stutters are still there, just not as much anymore. At least something. Still yet to visit the office I'm planning to test this PC at, but defo gonna do it.
MegaMelmek
Post by MegaMelmek » 25 Aug 2022, 01:14
mybad wrote:
24 Aug 2022, 04:31
If you use online UPS with battery you have common ground with the PC and the UPS
How long time can your UPS operate without input power on 500W PC- max 10min aprox? Battery that can charge and discharge at the same time do not exist so your online UPS is from begining not capable fix your issue
Thatweirdinputlag
Post by Thatweirdinputlag » 25 Aug 2022, 01:39
TheKelz wrote:
24 Aug 2022, 12:58
24 Aug 2022, 01:19
I wish you didn't do that purchase mate. I literally did the same, basically scrapped the Aorus Ultra motherboard that I had with its 4000cl19 kingston fury ram, and got Maximus Hero "Z390 though" with G.Skill 4000cl15 2x8! It was wonderful the first couple of days until it was not!
