The thing is I'm running a 5950x with a 3070. This config can easily keep above 250 fps regardless of scenario and in the practice range it's definitely 350 fps+ esepcially when I'm just standing still. I can't see how under any circumstance my system would have 100.jorimt wrote: ↑18 Oct 2022, 09:31Since Reflex uses a dynamic FPS limit to prevent GPU usage from maxing, something in it's behavior may briefly engage the dynamic limit during the larger frametime spikes/variances, causing what I assume would be a relatively benign effect if you're system is already momentarily dropping to 100 FPS during said variance (which is usually too brief to be picked up by overlays like Afterburner due to polling report limitations)
Can anyone confirm on their end?
Edit: Ok I got lucky. As I was looking at the SIM, received a discord notification. It went up as that appeared on screen. Switched off discord and now the most I saw was 6.1ms. Turned reflex off and most I saw was 6.0ms. I still don't know what is accounting for the 0.2-0.3 difference but it seems to have been Discord overlay as the culprit. Is it stupid to say the discord overlay is likely internally running like 60 fps or something so when it pops up reflex is fighting it? idk but atleast that's been addressed.
