SvenL
Post
by SvenL » 09 Nov 2022, 03:16
lizardpeter wrote: ↑08 Nov 2022, 19:09
In my own experience I would definitely say that's not true. I do not think it's easier to see enemies on IPS. It is, however, certainly easier to see them on 1440p screens (I have one of those too).
Oh, interesting! Thank you very much.
XL2566K vs Asus' new 1440p panel will be a really tough choice then
daviddave1
Post
by daviddave1 » 09 Nov 2022, 06:46
SvenL wrote: ↑08 Nov 2022, 15:25
lizardpeter wrote: ↑08 Nov 2022, 13:26
Can I ask why? I have a 240 Hz TN monitor and a 390 Hz IPS monitor. I vastly prefer the look and feel of the TN panel but ultimately use the 390 Hz IPS for the faster refresh rate and lower latency. I would definitely go with the Zowie XL2566K in your position. Or you could go for the new ASUS PG27AQN 1440p 27" monitor as it is BY FAR the best performing IPS panel out with response times that finally rival fast TN panels. You could use it in the 25" mode.
I've heard a lot of people say that with TN panels they have more trouble seeing enemies because of the lower color gamut, especially in battle royales like Warzone. Since you have an IPS and a TN panel, is that true?
one of the big upside of the XL2546K are the color, black equalizer and sharpness settings. IPS colors bleed. Example: if a enemy in a green outfit is laying in the grass, or a dark enemy in the shadows a IPS panel will have hard time distinguish the 2. where on the zowie its no problem. If u care more about visibility then go with the zowie. if u really care about inputlag allot get the acer 390hz ( the 650 euro 360 hz ZOWIE is the best of both worlds)
| Now:
| Past: XL2586X 540Hz/PG248QP/271QRX/VG259QM with the Qisda panel/PG27AQN/XL2566K
SvenL
Post
by SvenL » 09 Nov 2022, 10:35
daviddave1 wrote: ↑09 Nov 2022, 06:46
That's good to know! Thanks for the info.
