Page 2 of 2
Re: XL2720T Bad Ghosting and blur.
Posted: 05 Jul 2014, 08:14
by Falkentyne
Q83Ia7ta wrote:
Falkentyne wrote:
Q83Ia7ta wrote:
Falkentyne wrote: It's just how Benq's AMA is...it is much worse than Asus' tracefree
The vg248QE does look nicer motion blur wise, but then you have to deal with the purple tint, and the random 'scanlines' problem
I had purple tint and random scanlines problems at while experimenting with LightBoost at BenQ XL2411T :(
The VG248QE and the XL2411T are BOTH the exact same panel. (same part number by AU Optronics). So you will have the exact same 'issues'--scanlines, purple tint, etc.
The 27" monitors by AU are different, so that doesn't happen on those. (you may still see very faint scanlines at high Vertical totals though).
Posted: 05 Jul 2014, 12:28
by Q83Ia7ta
Falkentyne wrote: The VG248QE and the XL2411T are BOTH the exact same panel. (same part number by AU Optronics). So you will have the exact same 'issues'--scanlines, purple tint, etc.
I thought you wanna only VG248QE has this troubles: "The vg248QE does look nicer motion blur wise, but then you have to deal with the purple tint, and the random 'scanlines' problem"
