Everything about latency. This section is mainly user/consumer discussion. (Peer-reviewed scientific discussion should go in Laboratory section). Tips, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
Smokq
Post
by Smokq » 06 Dec 2022, 04:23
greenenemy wrote: ↑05 Dec 2022, 14:57
You can actually measure input latency in both Valorant and Fortnite with FrameView.
viewtopic.php?f=10&t=10682
Maybe that would help you or us find the cause of your problems.
Hello I tried to use that program but I dont really know how it works, I recorded my screen while using it, I don't know if that's what you meant:
https://www.youtube.com/watch?v=-hCbqgrMomQ
I also got some files but I cant open it because I think you need Exel to see the graphs, I tried to open it with a different app and this is what I see tho:
https://imgur.com/f9jXIax
Thanks for the reply
Smokq
Post
by Smokq » 06 Dec 2022, 04:30
F1zus wrote: ↑05 Dec 2022, 18:24
Your problem is not with the PC but with bad dirty electricity.
Just plug the iron into the outlet along with the computer, or even better, the electric oven and look at the movement of your mouse. If the mouse becomes sharp, then the problem is 100% electrical.
I dont use a power strip anymore for like 2 months ago, because I was testing if my outlet was fucked and now I have my whole setup plugged directly to my walls, I have like four plugs in my room and I used all of them for my pc/ router / monitor to see if that worked, I think there's no differences with that, but okay I can try to use again my power strip and plug all of the things you said together if thats what you mean. Thanks for the reply
greenenemy
Post
by greenenemy » 06 Dec 2022, 08:01
Smokq wrote: ↑06 Dec 2022, 04:23
Your PC latency seems to be very good there might be something else that is wrong and makes you feel heavy but idk what.
Smokq
Post
by Smokq » 06 Dec 2022, 09:40
greenenemy wrote: ↑06 Dec 2022, 08:01
Its so weird because even having that good numbers it feels so bad in every game
. Also I want to mention that there's a orange/yellow light blinking every 2-3 seconds all the time on my ASUS PRIME B450-PLUS motherboard, I tried to find what it means and I still dont know what does that mean, I cant really tell where is the light coming from, but I see the light coming next to the gpu, I tried to find info about this, but 0 idea, I saw that I can turn off this lights on the bios but I dont know if there's something wrong with it, maybe is not important but whatever I still have this shit input lag and I cant do anything ):
InputLagger
Post
by InputLagger » 08 Dec 2022, 18:56
Smokq wrote: ↑06 Dec 2022, 09:40
Use Google, please
https://www.reddit.com/r/ASUS/comments/ ... g_is_this/
Smokq
Post
by Smokq » 09 Dec 2022, 09:41
InputLagger wrote: ↑08 Dec 2022, 18:56
Use Google, please
I saw that already, and btw that's not even my motherboard, I dont think thats the main issue of my input lag, I just wanted to add that I have that and I have like a cold boot, that makes my pc boot twice everyday I turn on the pc, my last conclusion after "using google" is that the light is not the issue, I dont really care much about the light, I just care about my input lag issue that its impossible to fix because I tried EVERYTHING on the internet xd, thanks for the reply tho
