This fixes the electrical input lag
Locked
internetexplorer4
Re: This fixes the electrical input lag
Post by internetexplorer4 » 12 Dec 2022, 15:40
texre wrote:
12 Dec 2022, 13:00
dervu wrote:
12 Dec 2022, 12:54
Don't be so fast. To be sure, you need months of PC working as expected.
However, I can confirm that it works as fixed. :mrgreen:
You have one ? And it works for you? I’ve spent so much money trying to fix this problem don’t wanna waste more money trying to Play on grid
why are you not satisfied playing off grid? because I was actually planning going off grid after I confirm that my problem is 100% electrical. I mean it is the most accurate way to get rid of this problem, right? I don't know but I imagine that equipment like this that filter electricity may have the chance of not solving 100% of the problem although it gets way better. But I have a bit of a fear that it gets only 80% or 75% better. So going off grid wouldn't have this kind of doubt because there's no electricity so I would know that it was 100% gone
texre
Post by texre » 12 Dec 2022, 16:34
dervu wrote:
12 Dec 2022, 14:10
https://airlinktransformers.com/product ... -eucbs1500
Don't blame me, if you buy and it turns out bad after long time.
Time from buy to delivery at my place was around 2 weeks. Total cost with tax and delivery 560 eur + external RCD plug to be safe + power bar needs to have double pole switch - mine already had that (because current goes on both lines simultaneously). You can ask them to place RCD for additional fee.
My god I love you if it stays like this
MegaMelmek
Post by MegaMelmek » 12 Dec 2022, 19:18
I am using something like this is same like yours isolated transformer but more poverfull and not that expensive
https://www.hityshop.cz/stabilizator-na ... ncQAvD_BwE
It kinda help and kinda not
dervu
Post by dervu » 13 Dec 2022, 03:07
MegaMelmek wrote:
12 Dec 2022, 19:18
It is not the same thing. Voltage stabilizer/regulator is not isolation transformer and usual isolation transformer is not balanced transformer.
cybepine
Post by cybepine » 13 Dec 2022, 03:22
dervu wrote:
12 Dec 2022, 13:06
texre wrote:
12 Dec 2022, 13:00
dervu wrote:
12 Dec 2022, 12:54
Yes, I have it for very short time. Not the same one as OP, but from another reputable manufacturer.
If you do not want to risk money, don't. Just wait for long term confirmation, but people are impatient...
Really glad to hear! :)
You are right, wait for a few weeks to ensure it is fixed.
I have mine here too (just arrived). I have to buy new power cables and strip for it. And I have been too busy to test it.
I write my test report at the earliest in January.
I have to confess something. I'm an engineer, but not an electrical engineer.
wadge
Post by wadge » 13 Dec 2022, 09:47
cybepine wrote:
13 Dec 2022, 03:22
dervu wrote:
12 Dec 2022, 13:06
texre wrote:
12 Dec 2022, 13:00
dervu wrote:
12 Dec 2022, 12:54
What type of power strip ? can you post a link ?
MegaMelmek
Post by MegaMelmek » 13 Dec 2022, 10:30
dervu wrote:
13 Dec 2022, 03:07
MegaMelmek wrote:
12 Dec 2022, 19:18
Its absolutly the same you need read the specs...
Specs from your machine : Product Type Safety Isolating transformer
cybepine
Post by cybepine » 13 Dec 2022, 11:55
MegaMelmek wrote:
13 Dec 2022, 10:30
dervu wrote:
13 Dec 2022, 03:07
MegaMelmek wrote:
12 Dec 2022, 19:18
It is Voltage stabilizer/regulator. Like Dervu said. It is not isolation transformer. It does not separate hot and neutral.
I don't advertise products here. 2 normal IEC power cords and aluminum power strip. No filtering, no surge protection, no switch. Normal power strip, but it is made from high quality materials.
texre
Post by texre » 13 Dec 2022, 18:54
The transformer gets infected as well worked good for only 1 day
delve
Post by delve » 13 Dec 2022, 18:58
i think ground is still passed through in these transformers, so you a are not totally isolated from the grid.
Maybe charge your batteries with the transformer and see if it makes any difference.
Locked
