Need HELP TO FINALLY FIX MY 5YEARS INPUT LAG PROBLEM
imprecise
Re: Need HELP TO FINALLY FIX MY 5YEARS INPUT LAG PROBLEM
Post by imprecise » 22 Dec 2023, 01:14
akka111 wrote:
20 Dec 2023, 10:19
okey, i buyed new rams " G.SKILL Ripjaws DDR4 16GB 2x8GB 3200MHz CL16 DIMM 1.35V XMP 2.0 "
why other settings not changing with new rams i will show in photo, old rams was very cheap so i decided to change it . "old rams is tcl 22" https://imgur.com/a/cJv42QQ
https://imgur.com/a/zYQwAKI
Those 2 images show 2 different types of RAM. Did you leave an old stick in?
I forgot to mention another thing that always affects my mouse movement is power saving on the USB devices.
To the above reply, that MAC/Win network mouse issue may be related and it also may be fixable with the changes I suggested. I don't have that setup currently to test, so someone else would need to try and report back here.
akka111
Post by akka111 » 22 Dec 2023, 01:39
yes i showed old rams with cl22 and new cl16, but other settings doesnt have to change with that ? and one more thing in bios i cant disable ftpm for some reason, then i press default bios settings its showing that they changing ftpm to dtpm but after rr i see its ftpm checked
