Page 2 of 4
Re: gpu scaling vs Display scaling
Posted: 14 Jan 2023, 11:12
by timecard
Regarding fullscreen, aspect ratio, no scaling (centered)
Reference:
https://learn.microsoft.com/en-us/windo ... ig_scaling
https://learn.microsoft.com/en-us/windo ... ktop-image
How Nvidia control panel scaling setting maps to Windows scaling
Registry setting that changes:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers\Configuration\<monitordeviceinstancepath>\00\00\Scaling = X
Posted: 15 Jan 2023, 01:03
owslahd97 wrote: ↑
14 Jan 2023, 10:33
It stands to reason that an input lag of <1ms should not be noticeably perceived by people.
FWIW, thread Milliseconds Matters. Sometimes the sub-millisecond context does matter, but "it depends".
Posted: 15 Jan 2023, 19:39
by Shade7
timecard wrote: ↑
14 Jan 2023, 11:12
Reference:
Very interesting.
To me, it makes sense how the different methods of scaling might lead to different results (no matter how small- <0.5ms, 1ms, etc.) when using a different resolution/aspect ratio than your monitor's native.
But do these settings make a difference when you are using your monitor's native resolution?
I can't seem to find an answer to the following question.
1. If my monitor's native resolution is 1920x1080, and I'm using it at that resolution. Does toggling between the different scaling options (aspect, fullscreen, no scaling) make any difference to the image presented? From what I've read online (not sure how true this is), people say that you should be setting it to "no scaling" when using your native resolution, since the other 2 scaling options would add some sort of extra/unnecessary processing.
Posted: 18 Jan 2023, 13:11
by Zodasaur
Shade7 wrote: ↑
15 Jan 2023, 19:39
timecard wrote: ↑
14 Jan 2023, 11:12
Reference:
Very interesting.
No.
Posted: 21 Jan 2023, 07:25
by Traveler
What about integer scaling?
Posted: 21 Jan 2023, 15:01
by owslahd97
Traveler wrote: ↑
21 Jan 2023, 07:25
If the game you play is a high frame rate FPS competitive game, like CSGO VALORANT Fortnite...I'm pretty sure integer scaling must be the worst, But I don't know about other types of games
Posted: 21 Jan 2023, 15:03
by owslahd97
Zodasaur wrote: ↑
18 Jan 2023, 13:11
Shade7 wrote: ↑
15 Jan 2023, 19:39
timecard wrote: ↑
14 Jan 2023, 11:12
Reference:
Very interesting.
No.
Since there is no difference, then treat it as a placebo, although I can completely perceive his difference. .
Posted: 23 Jan 2023, 16:12
by Coolhigh
My set up
3090ti
2566k
13900k
Gpro superlight and g502x
800dpi
I play overwatch 2 and valorant
Gpu or Display/No scaling
It always gives me icy feeling. Its very hard to control my mouse.
Display/Fullscreen
it feels like the least input lag but it gives me slight icy feeling. I can still play decent sometimes.
Gpu/Fullscreen
mouse feels consistent. I can actually track the target.
I think 500hz polling rate helps me a lot with overall icy feeling when i play overwatch 2.
Also with XMP on, i have a problem with inconsistent mouse movement. It feels like my mouse is accelerating sometimes. (My set up has 0 acceleration and 0 smoothing )
Mouse feels like super icy and fast. I can not aim when this happens. So XMP off works for me.
Posted: 27 Jan 2023, 15:24
by Traveler
owslahd97 wrote: ↑
21 Jan 2023, 15:01
Traveler wrote: ↑
21 Jan 2023, 07:25
What is high FPS, anything above 270-300?
Posted: 30 Jan 2023, 15:03
by Mr1991
timecard wrote: ↑
14 Jan 2023, 11:12
Reference:
Wasn’t there a setting for “1” in the scaling registry? Can’t remember where I read about it
