I think people that r watching and reading our arguments, clearly understood what's the difference between u and me, but just for the record,Future wrote: ↑21 Jan 2023, 20:01Brotha, where in all my posts you read the word "laptop" when I clearly stated that I borrowed an old PC? Do you even read what people write when you blame others that "they are too lazy to read"? And what dafuq is common and how did you make an associaton between an OS and your imaginary EMI issue? Glad you mentioned the pro players. If the cause of your issue was really EMI, how ffs these players haven't noticed it when they change so many different places, more than you change your pants? Now that there is a tournament, Blast CS GO, and all these guys play pc to pc, if you run an EMI meter or oscilloscope or any other tool that measures such things, do you have any idea what would the numbers be? You will declare them "infected", because this is the word you guys use. But their gameplay is great, as it should be. And what stops you to go to some location with good electricity and no EMI issues, one where pro players have/had bootcamp or an event? Most of them are really cheap. Now that you mentioned "laptop", what if you have a laptop and you run it on battery power? How is your imaginary EMI issue causing input lag to it too? Have you ever asked yourself if there was even 1% truth in what you are obsessed with, that the last thing you would've experienced is input lag? If it was that easy for something to cause issues and to affect that many people, then the computer parts manufacturers would've gone bankrupt, buddy. Why XP fixes my input lag? I have no idea, maybe it handles interrupts differently or something implemented later in the newer OSes. Why do pros don't have it? I don't know, maybe because their systems are optimized by experts. I have no idea, but I know for sure that the symptoms we all describe cannot be caused by something like that. If it could, it would've been proven and it would've been fixed at least by one person on the planet Earth.mortez123 wrote: ↑21 Jan 2023, 16:33And I told u already, I don't decline what u found, it is true, XP is different in anyway. But it's not the point, the point is, u can't play new games in it, so it can't be a solution, plus, if other windows versions have issues, why streamers doesn't have issues in it, plus even if we buy their exact specs, why we can't play like them? Why some houses doesn't have issues but ours does? It have a simple solution like I said in this topic, but I need to be able to completely prove it, without being trolled by electricians, that was why I came and gave a probably temporary solution untill I can give u the exact source, proves of it, solution and proves of it.Future wrote: ↑21 Jan 2023, 13:08As I told you earlier, your "solution" is not something that hasn't been tested long ago and proven to be a non-working waste of money. This thing costs like 150 euro in my country. Instead of spending 150 euro or the equivalent in your currency, just buy a second hand 20 euro pc, install Windows XP and check if you have input lag. You can even use the same outlet that you normally plug your pc. When you realise how far you are from a solution of the problem, I can guarantee you that you won't consider EMI or anything power related as a cause for your issue never again. You may ask how can I be so sure - during the years I've heard many people complaining about input lag, some of them made videos and from what I've seen, mine is like at least ten times worse. The moment I borrowed that old pc with Windows XP, my input lag problem vanished. The moment I tried to install newer OS it was there. Even on Windows 7 with DWM disabled. I wrote it in another thread and I will write it here also, try it yourself. Instead of spending thousands of dollars/euro for new PCs and perephrials, just buy an old pc and see how wrong you are.
So this is not the solution, don't say it more, bcs I already said it.
BTW, there r some things about your solution that I can tell:
1. I don't understand which one was your solution? Once u say it's XP, once u say old laptop, once u say I'm not talking about old laptop, I'm talking about XP, but then again u come here and say buy a 20 Euro laptop and install XP in it. I'm just confused.
2. If u say it's XP, why u loaf (not sure if it's a polite word or not) around here in EMI section? I'm again confused.
3. The reason why XP works that good in your old laptop is 2 thing:
A and B, I explain A now, but I will explain B in my next topic, but till then, I appreciate u if u take a pic from your laptop and all of it's ports and send it here, or just give me it's name. Thanks.
But for now, about A, the reason why XP works in this term, is its same as underclocking which people claimed that it worked too or enabling spread spectrum in bios which actually limits some horses of PCs. Why they r same as each others? Easy, do u remember when I said that PC itself produces EMIs? The more PC works, the more it produces EMIs, so if XP is good is bcs it doesn't use that much horses of PCs, same as underclocking, same as spread spectrum.
I didn't want to tell it now, but I told it now only to prove u, that I know why some things works but they r not as good as those times we don't have issues. And to prove u I am familiar with them.
So wait if u want the full answer.
BTW now that I think a bit more, I can tell a bit about B too, so the reason why your old laptop works better is the same as why a PS4/5 works better than PC. But I'm not sure that much about B, so I need to know your laptop name too. Then I can say if B is correct or not, not here but in my next topic.
First, yeah I'm sorry, I was wrong, I thought it was a laptop, ok something was in my mind like I stored into it wrong data. Sorry, now that I know it's a PC, probably I'm wrong with the B.
Second, speaking of a laptop and playing with it's battery, now I can say one difference between u and me and it's that my theory is based on other people's story, but yours is only based on yourself story. I don't need to play on laptop battery, bcs people already claimed that when they r on UPSs battery, they have no issues with it, this is my proof one, and people already claimed that if they play on solar system, without any connection to power grid, they have no issues clearly, this is my second proof, and people already claimed that playing on generators again have no issues, and guess what, this is my third proof. BTW I have a very old laptop, but the problem is it's a gaming laptop, not sure about newer gaming laptops but older ones r not designed to play on battery, if u don't know already, gaming laptops use CPUs that have more power consumption, but non-gaming laptops don't, u can search about it and u will find lot's of proofs of this in your face. So these laptops have to underclock a lot when running on battery, bcs their CPUs won't let them to be on that much. So if u could play with 60 fps, on battery, u have to play with something like 30 fps, so clearly u can't tell if the problem solved with it or not, bcs fps changed down to a very lower fps which it's unplayable, at least mine is. But as I already said, people already prooved that playing off-grid cleared all issues, so I don't have to worry about.
Third, I believe in EMI, so I don't go anywhere else to find a solution, but u believe in XP, but u still search in other sections of this forum to find a solution. And u still don't have an answer to this. Tell if it's curiosity or changing other's mind, bcs we r totally ok with it. But u have to answer people's questions if you want to change their mind.
Forth. The biggest one is, I have every reasons of my theory that I can answer to questios. But u, even don't have yours, and I'm the one who comes and answers to your theory, in other words, I kill my enemies with my answers, and carry u too by killing your enemies with my answers. But u even can't kill your enemies with your answers.
Fifth, BTW I am lazy when reading, I already said it, but if u mean inattentive by the world lazy, I should say even if I am, I don't rely on one proof nor one fact, so that's another difference between u and me (do u remember A and B? If B rejected which I'm not sure if it's completely rejected or not, but there is still A for it)
About the streamers, did ever this came into your mind that why streamers in Canada have less issues than most EU countries and wormer counties too bcs of different factor? See? I may have those answers too, and the reason I say may, is bcs I need more evidences to prove it. About bootcamps, clearly they r not us, they hire experts to get rid of any unsafe things that may interfere with PCs, which I'll talk about them too.
Now I hope u get the massage that my theory can answer almost everything.
