Page 2 of 2
Re: Stutters and framerate spikes since November 2022
Posted: 30 Mar 2025, 06:26
by Nestorfield
binodynamic wrote:
02 Feb 2023, 23:27
ontononton wrote:
02 Feb 2023, 17:15
hello OP.
Same issue here with a 5800x3d, I stutter mostly in cs go and pubg. Warzone, cyberpunk and gta5 is fine. All games were also fine when it was just a 5800x there :/
Unfortunately 7800x3d won’t be out until April so I won’t be able to resolve this until then. Not sure if you had seen it but I decided on swapping over to am5. Will update when I make the change.
Hello, it's been a while, i have the same issues with the same CPU. Did you fix your issue?
