24G2U Distortion at "Moving Photo" test , videos, vsynced/fps capped games
Boomchakadah
Re: 24G2U Distortion at "Moving Photo" test , videos, vsynced/fps capped games
You need freesync/G-sync in order to remove screen tearing. Any particular reason why you don't like G-sync?
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
Solution:
Reset your NVIDIA Control Panel settings and make sure you're not using VSYNC OFF for fullscreen mode.
Ideally, you should only set VSYNC OFF on a per-application basis, and never for global fullscreen usage.
Manage 3D Settings -> Global Settings -> Vertical Sync -> Use the 3D application setting
For TestUFO, you don't want web browsers such as Google Chrome to use VSYNC OFF in fullscreen mode.
If you want to force VSYNC OFF, do it via in-game and/or the Program Settings.
EDIT: Also restart browser if you're getting tearing in TestUFO, or better yet, restart computer
While this is an alternative successful solution, this doesn't address the underlying cause;Boomchakadah wrote: ↑14 Apr 2023, 19:04That looks like screentearing.
Does it happen at lower refresh rates like 60hz as well? does it happen in microsoft edge?
Make sure hardware acceleration is enabled in Chrome settings. Make sure Freesync is enabled. If you have an Nvidia GPU, make sure G-SYNC for full screen is enabled.
Run a frame-skipping test to make sure your monitor isn't skipping frames. https://youtu.be/3xiPSkQSX5A?t=194
The problem is actually slightly different; the problem is the user has a global VSYNC OFF setting in their graphics drivers that needs to be removed/deleted/undone. The global setting is interfering with applications that user doesn't want VSYNC OFF in.
Then the "Use application setting" will automatically use VSYNC ON in the software (emulators, Chrome, fighting games) that works best with VSYNC ON. The user can still use G-SYNC instead, simply by configuring Program Settings to G-SYNC and then configuring the in-game menus to VSYNC OFF.
amorou
Enabling g-sync solves it , so how to fix it without g-sync ?Boomchakadah wrote: ↑15 Apr 2023, 04:11Yes.
If enabling Freesync/G-sync doesn't fix it, there is something wrong with that monitor. Return it or contact AOC for a replacement.
Instructions: viewtopic.php?f=19&p=93148#p92955amorou wrote: ↑23 Apr 2023, 18:02Enabling g-sync solves it , so how to fix it without g-sync ?Boomchakadah wrote: ↑15 Apr 2023, 04:11Yes.
amorou
Ah, gotta restart browser to see if changes has effects , issue solved thanksChief Blur Buster wrote: ↑23 Apr 2023, 18:08Instructions: viewtopic.php?f=19&p=93148#p92955amorou wrote: ↑23 Apr 2023, 18:02Enabling g-sync solves it , so how to fix it without g-sync ?Boomchakadah wrote: ↑15 Apr 2023, 04:11Yes.
