I am more interested in scanning BFI though.Chief Blur Buster wrote: ↑13 Dec 2025, 19:55However, you can fix crosstalk completely if you use the refresh rate headroom trick:
Viewsonic XG2431 Settings Help
betonKruglosuTotchno
Re: Viewsonic XG2431 Settings Help
Yes, rolling can be better! But it's hard to get it in a product, and sometimes the scanning method still creates strobe crosstalk from the internal light diffusion (illuminated bar leaking into the unilluminated parts of the screen)betonKruglosuTotchno wrote: ↑16 Dec 2025, 18:28I am more interested in scanning BFI though.Chief Blur Buster wrote: ↑13 Dec 2025, 19:55However, you can fix crosstalk completely if you use the refresh rate headroom trick:
It can also be done via software-based means if you have brute refresh rate, e.g. low motion blur 60-120fps on a 240-480Hz OLED.
See it within TestUFO (turn off strobing/PureXP before using software-based motion blur reduction):
www.testufo.com/crt
You can also run CRT simulator in the new ShaderGlass CRT alpha. It tends to perform best on 240-480Hz OLEDs.
radeko
Has anyone considered hardware modification of the strobed LED display? Replacing LED diodes and driver with more powerful ones?
LG C1 55"
