Page 2 of 2
Re: Viewsonic XG2431 Settings Help
Posted: 16 Dec 2025, 18:28
by betonKruglosuTotchno
13 Dec 2025, 19:55
However, you can fix crosstalk completely if you use the refresh rate headroom trick:
I am more interested in scanning BFI though.
Posted: 18 Dec 2025, 20:46
betonKruglosuTotchno wrote: ↑
16 Dec 2025, 18:28
13 Dec 2025, 19:55
Yes, rolling can be better! But it's hard to get it in a product, and sometimes the scanning method still creates strobe crosstalk from the internal light diffusion (illuminated bar leaking into the unilluminated parts of the screen)
It can also be done via software-based means if you have brute refresh rate, e.g. low motion blur 60-120fps on a 240-480Hz OLED.
See it within TestUFO (turn off strobing/PureXP before using software-based motion blur reduction):
www.testufo.com/crt
You can also run CRT simulator in the new ShaderGlass CRT alpha. It tends to perform best on 240-480Hz OLEDs.
Posted: 31 Dec 2025, 15:24
by radeko
Has anyone considered hardware modification of the strobed LED display? Replacing LED diodes and driver with more powerful ones?
