Windows 11 Update Fixes High Polling Rate Stuttering
olofsson_tom
Re: Windows 11 Update Fixes High Polling Rate Stuttering
Post by olofsson_tom » 21 Jun 2023, 03:29
mago wrote: ↑
21 Jun 2023, 00:56
Bobo wrote: ↑
20 Jun 2023, 18:28
do you mind sharing that driver?
Where did you find this driver? It is used for all amd processors? Chipsets?
mago
Post by mago » 21 Jun 2023, 04:35
win11 newest iso by Microsoft in the winsxs folder yea 64bit
Chipsets? duno
Ⓢк𝕀lŁ เ𝓢 ᵗⒺм𝕡σr𝐀𝐑Ⓨ, lά𝔾 I𝐬 F𝔬ʳ𝔢𝓿ᗴ𝔯
olofsson_tom
Post by olofsson_tom » 21 Jun 2023, 05:07
mago wrote: ↑
21 Jun 2023, 04:35
Chipsets? duno
Ok thanks, just installed windows 11 :)
Mr1991
Post by Mr1991 » 21 Jun 2023, 11:05
Bloedboer wrote: ↑
20 Jun 2023, 05:09
Perfect that’s sooner than what was told. It was expected later this year. Did some polling tests.. first time ever my g pro stable 1000hz except for when I tried the insider. Tnx for answering Chief 🫡
On desktop, or in a game?
Bloedboer
Post by Bloedboer » 21 Jun 2023, 11:17
Desktop.
Anonymous394872
N/A
Post by Anonymous394872 » 27 Jun 2023, 05:29
N/A
Kaled
Post by Kaled » 29 Jun 2023, 09:12
Someone made a video on the topic about his experience with several games (CSGO, BattleBit Remastered, Apex Legends, Valorant, OW2)
https://www.youtube.com/watch?v=Own0hGCSzwg
masneb
Post by masneb » 30 Jun 2023, 06:13
Huh... Anyone else have basically three solid lines now at 1000,1050,950hz after the update? I'm not sure this is better or worse as I haven't really gotten to test it out, but concerning... All my internal hubs yield the same results (4 of them), some more solid lines then others, but basically three lines for all of them. 8000hz graph is extremely ugly.
I have a 7950X3D and a B650 motherboard.
Need someone to check input latency with the new update as well. Coalescing or basically packaging multiple polls into the same packet means there is more then likely a buffer and input latency introduced. However, depending on how they do it, it might be very small.
phx
Post by phx » 01 Jul 2023, 14:05
After this update I have a smooth mouse but I have a bug after pc sleep my viper 8kHz only works 1kHz... and when I switch to 4kHz mouse only 500hz (wtf?) restarting the computer doesn't fix it and synapse, only usb reconnection fixes it.
I don't use synapse, the whole process is closed, I switch profiles with mouse buttons.
Does anyone else have this?
Post by Slender » 01 Jul 2023, 17:42
masneb wrote: ↑
30 Jun 2023, 06:13
hahahaha i have same lines on intel amd with nvidia gpu
intel delta 998-1002 gpu on, 999.5-1000.5 gpu off.
amd delta 990-1010 gpu on, 999/1001 gpu off.
