Page 2 of 4
Re: Windows 11 Update Fixes High Polling Rate Stuttering
Posted: 21 Jun 2023, 03:29
by olofsson_tom
mago wrote: ↑
21 Jun 2023, 00:56
Bobo wrote: ↑
20 Jun 2023, 18:28
do you mind sharing that driver?
Where did you find this driver? It is used for all amd processors? Chipsets?
Posted: 21 Jun 2023, 04:35
by mago
win11 newest iso by Microsoft in the winsxs folder yea 64bit
Chipsets? duno
Posted: 21 Jun 2023, 05:07
by olofsson_tom
mago wrote: ↑
21 Jun 2023, 04:35
Chipsets? duno
Ok thanks, just installed windows 11 :)
Posted: 21 Jun 2023, 11:05
by Mr1991
Bloedboer wrote: ↑
20 Jun 2023, 05:09
Perfect that’s sooner than what was told. It was expected later this year. Did some polling tests.. first time ever my g pro stable 1000hz except for when I tried the insider. Tnx for answering Chief 🫡
On desktop, or in a game?
Posted: 21 Jun 2023, 11:17
by Bloedboer
Desktop.
N/A
Posted: 27 Jun 2023, 05:29
by Anonymous394872
N/A
Posted: 29 Jun 2023, 09:12
by Kaled
Someone made a video on the topic about his experience with several games (CSGO, BattleBit Remastered, Apex Legends, Valorant, OW2)
https://www.youtube.com/watch?v=Own0hGCSzwg
Posted: 30 Jun 2023, 06:13
by masneb
Huh... Anyone else have basically three solid lines now at 1000,1050,950hz after the update? I'm not sure this is better or worse as I haven't really gotten to test it out, but concerning... All my internal hubs yield the same results (4 of them), some more solid lines then others, but basically three lines for all of them. 8000hz graph is extremely ugly.
I have a 7950X3D and a B650 motherboard.
Need someone to check input latency with the new update as well. Coalescing or basically packaging multiple polls into the same packet means there is more then likely a buffer and input latency introduced. However, depending on how they do it, it might be very small.
Posted: 01 Jul 2023, 14:05
by phx
After this update I have a smooth mouse but I have a bug after pc sleep my viper 8kHz only works 1kHz... and when I switch to 4kHz mouse only 500hz (wtf?) restarting the computer doesn't fix it and synapse, only usb reconnection fixes it.
I don't use synapse, the whole process is closed, I switch profiles with mouse buttons.
Does anyone else have this?
Posted: 01 Jul 2023, 17:42
by Slender
masneb wrote: ↑
30 Jun 2023, 06:13
hahahaha i have same lines on intel amd with nvidia gpu
intel delta 998-1002 gpu on, 999.5-1000.5 gpu off.
amd delta 990-1010 gpu on, 999/1001 gpu off.
