Best G-Sync settings for single player games
Kyouki
Re: Best G-Sync settings for single player games
Post by Kyouki » 19 Dec 2023, 03:06
If you use in-game Nvidia Reflex this cancels out Nvidia control panel setting to Low-Latency, so would ignore that and use Reflex where possible.
try Reflex On + Boost (auto-caps the framerate to properly suffice G-sync) you're doing already a pretty good set up, though test if V-sync ingame may not be better than the driver, else always use the driver one.
Otherwise, jorimt's words are proper.
