Page 2 of 2
Re: Emi/rfi question
Posted: 28 Jan 2024, 06:49
by minathor
InputLagger wrote: ↑25 Dec 2023, 22:14
pcenthusiast92 wrote: ↑08 Nov 2023, 23:05
Hello good evening, I was wondering if dirty electricity/rfi can actually cause blurryness /motion blur? for some reason no matter what I do with my computer (in terms of tweaking, latency) , It's like my eyes lost the track while playing games; as Lost Ark, Diablo 4, Heroes of the Storm, is hard to explain when I'm moving or things are in moving even if my mouse cursor is stuck on my character, I can easily lost myself
And for some reason games feel accelerated mostly the animations, are faster, but at the same time games feels visually lag, I can't react at time.
I have already follow amazing guides over there in github, tested/tweaked 2-3 computers since 2011, and problem persist.
As adult I only lived in 2 houses, last house was a bit better, but on this one, seems like my eyes dried so fast, got more eyestrain, etc,etc
Only thing I never was able to get/buy was a gaming monitor, but I have seeing persons playing at 60hz monitor with 5ms response time and they do flawless their game looks smooth, and not over-speed
PS: This never happened in my old,old house back in 2009 (had a phenom amd paired with fx 5200, crt monitor at 60-75hz)
I apologies in advance for my poor grammar ^^
Cheers.
Extract same symptoms (accelerated animations,enemies always faster than you, eyes just loose focus on monitor) with my amd fx 8350 build since ~2013y
I was able to partially fix icy, muddy, accelerated mouse feeling by adjust correct cpu voltage for current overclock) Even on stock freq cpu didn't have enough voltage as prime95 tells me
I also have fx 8350, what is was your mobo and custom voltage?
Posted: 09 Feb 2024, 18:48
by InputLagger
pcenthusiast92 wrote: ↑27 Jan 2024, 15:50
Cheers.
Oh sorry for not answer at time, I forgot about this website, but thanks god we are not alone with this situation.
"Even on stock freq cpu didn't have enough voltage as prime95 tells me" I'm curious about your quote, what test should I realize on prime95? I have a ryzen 5 1600 not the AF, just the first ryzen 5 1600, and I run it on stock, where can I check in prime95 that alert of not having or having enough voltage? would you mind to explain me what option or preset should I select thanks
The prime95 tests should run without any rounding errors. You can also test cpu via OCCT, this program also should run without any errors. Adjust voltages if needed (increase ofc)
Posted: 09 Feb 2024, 18:55
by InputLagger
minathor wrote: ↑28 Jan 2024, 06:49
Cheers.
M5A99FX PRO R2.0, but it doesn't really matter here much as you should find
your own voltages for your own CPU (thanks, silicon lottery
)and overclock, but don't go above 1.45v on vcore, because of frying cpu risk
