Batch file to turn off 8->10bit dithering in NVIDIA GPUs on Windows
There are over 100 ergonomic issues from displays, far more than just flicker and blue light. This forum covers the giant variety of display ergonomics issues.
Re: Batch file to turn off 8->10bit dithering in NVIDIA GPUs on Windows
Post by Chief Blur Buster » 18 Feb 2026, 18:33
AVE10N wrote: ↑
17 Feb 2026, 19:11
Hi! (Sorry, I'm using Google Translate.) I need help. I used the novideo_srgb program to test if I'm sensitive to dithering. I turned it on and immediately felt discomfort in my eyes. I turned it off, but the effect didn't go away and my eyes continued to hurt. I've uninstalled the graphics card drivers and reinstalled Windows 11, but nothing helps. I've never had eye pain from this monitor with this RTX 3060 graphics card before. Please tell me what else I can do to restore everything to how it was before.
Try This:
- Try a full total hard reboot. Turn off, then unplug computer, then plug computer, then turn on.
- This will reset both GPU and OS if it was simply a temporary (volatile) setting.
Failing This:
- Uninstall all your computer monitor calibration data (ICC files, INF files, etc)
- Do a driver clean. Full NVIDIA driver uninstall and reinstall.
Last Resort:
Start novideo_srgb again and undo it using that program.
https://github.com/ledoge/novideo_srgb/issues/127
This might be your issue.
