Talk to software developers and aspiring geeks. Programming tips. Improve motion fluidity. Reduce input lag. Come Present() yourself!
Post
by Chief Blur Buster » 19 May 2024, 19:54
jon-mil-92 wrote: ↑19 May 2024, 19:03
I believe I have the code base pretty well modularized to make a Linux version easier. I'd have to expand the Java (low-level) System Hook dependency to support native Linux key events though, since it currently only supports Windows. This is what would take most of the time. Creating the libraries to apply the display settings in Linux wouldn't be too hard.
Great, perhaps all you need is calls to command line
ddcutil and
xrandr (etc)
That's one method of switching resolutions and display settings via cli.
If your code compiles under Linux when blanking-out your WIndows calls, then a Linux version might be easier than you expected.
jon-mil-92
Post
by jon-mil-92 » 29 May 2024, 09:02
Hello all!
I have updated the roadmap for the project on the GitHub and on the Display Hot Keys website. However, this update might take awhile because I am job searching at the moment. Once I secure a job as a software developer/ engineer, I'll be updating the project more regularly. Thank you everyone that has tried out my passion project! Hopefully you find the software useful! Stay tuned for more updates.
jon-mil-92
Post
by jon-mil-92 » 16 Jul 2024, 16:23
Hey all!
I'm just reporting in to let you know that I have finally secured a job in the industry as a software engineer. So, I will have a bit more time to work on this project now. I have begun the implementation for rotation support. Hopefully, I'll be able to get an update released this weekend for rotation support.
Update: I'm still working on adding rotation support. It was a little more involved than I had originally planned, but it is going well. I'll be sure to create a new post when the new version is up.
jon-mil-92
Post
by jon-mil-92 » 08 Sep 2024, 07:20
jon-mil-92 wrote: ↑16 Jul 2024, 16:23
Hey all!
I got display orientation mode (rotation) changes working with single-monitor configurations. I'm just trying to work out a bug with multi-monitor configurations before I package up the new build. I also added a button next to the display mode for each slot so that you can instantly apply the settings with the button rather than using the hot key.
Post
by Chief Blur Buster » 17 Sep 2024, 20:24
Nice, thanks for keeping me up to date.
Rotation support is often a tricky gotcha, especially when Windows detects monitor rotation when a DELL office monitor is rotated 90 degrees. The monitor sends a now-standardized event to the operating system, indicating current rotation of the screen. On others, it's a manual process.
BTW, if I don't respond, anybody in "The Laboratory" section can send me a PM to remind me to check their thread. I enjoy "The Laboratory" posts more than any of the other areas.
jon-mil-92
Post
by jon-mil-92 » 20 Oct 2024, 16:40
Hello all!
I have released version 1.4.0 of Display Hot Keys! You can grab it from here:
https://github.com/jon-mil-92/DisplayHotKeys/releases
Changelog
- Added display orientation mode selection support.
- Added an "Apply Display Mode" button to immediately apply a slot's display settings.
- Fixed component focus on restore.
jon-mil-92
Post
by jon-mil-92 » 09 Jan 2025, 09:30
If anyone has suggestions for features they'd like added, please comment here. I plan on adding settings saving/loading in the next update.
jon-mil-92
Post
by jon-mil-92 » 04 Jul 2025, 16:00
Hey blur busters!
I have released version 1.5.0 of Display Hot Keys! You can grab it from here:
https://github.com/jon-mil-92/DisplayHo ... tag/v1.5.0
Changelog
- Added the Minimize To Tray button to toggle whether or not to minimize the app to the system tray
- Added a taskbar icon for when the app is not minimized to the system tray
- Fixed a bug in which the display modes would not get sorted
- Fixed a bug in which the app window would maximize after waking the PC from sleep
- Fixed a bug in which the Orientation label would get cut off after changing resolutions
- Fixed a bug in which the app window would get corrupted after changing resolutions
- Fixed a bug in which the theme would not get properly set if the settings.ini file was deleted while the app was running, and then the app was refreshed
- Updated the FlatLaf dependency to version 3.6
- Updated the JDK to version 21.0.7
If you find this app useful and wish to buy me a coffee, consider donating using the PayPal Donate button in the app. Thanks!
jon-mil-92
Post
by jon-mil-92 » 09 Nov 2025, 09:21
Version 2.0.0 should be released soon. I added the ability to change the display orientation with hot keys! Each slot will have its own orientation mode now.
jon-mil-92
Post
by jon-mil-92 » 27 Nov 2025, 10:44
Changelog
- Moved display orientation selection to the slot so display orientation
can be applied with a hot key
- Updated the app to use the newly created GetDisplay DLL instead of the EnumDisplayIds and
EnumDisplayModes DLLs
- Updated the dialog confirmation message and title bar message for the
orientation and clear all dialogs
- Changed the way buttons are created and handled
- Major refactoring of the codebase
- Updated the FlatLaf dependency to version 3.6.2
- Updated the JDK to version 21.0.9
Release Notes
This release focuses on moving the orientation mode selection to the slot. This enables the ability to change the orientation of a display with hot keys. This release also focuses on bug fixes and dependency updates.
If you have Display Hot Keys version 1.2.0 or earlier installed beforehand, you must uninstall it before using the installer for version 2.0.0.
Grab the latest version here:
https://github.com/jon-mil-92/DisplayHo ... tag/v2.0.0
