jassine
Post by jassine » 25 May 2024, 11:52
JimCarry wrote: ↑
24 May 2024, 20:09
But you can openpowershell and type get-netadapteradvancedproperty and see you have rss if not you can add it by hand in the registry if you wish it so much.
i tried get-netadapteradvancedproperty and i dont see RSS, if you know how to do it with registry or have link please let me know.
jassine
Post by jassine » 25 May 2024, 12:02
JimCarry wrote: ↑
24 May 2024, 21:44
When i open he "Msi_util ver3" Realtek net adapter was High priority and in msi mode on,Should i untick the msi mode off like i use to have it ? and should priority be High or Undefined like yours?
As they said before, every pc has its own config, try enable MSI_mode and see the performance, then disable it and compare. These network cards act differently from pc to another.
JimCarry
Post by JimCarry » 25 May 2024, 12:37
jassine wrote: ↑
25 May 2024, 11:52
JimCarry wrote: ↑
24 May 2024, 20:09
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0000]
"*RSS"="0"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0000\Ndi\params\*RSS\enum]
"0"="Disabled"
"1"="Enabled"
"*RSS"="0"
Keep in mind i dont think this is the right way to do it i just show you my registry
and the final step is maybe after you add these dwords restart pc then go to powershell and see my screen yours says true then is on.
Unreazz
Post by Unreazz » 25 May 2024, 15:03
You can adjust or tinker with your NIC configuration as much as you like, but it won't significantly change your in-game experience. The only settings that might have a minor impact are flow control or interrupt moderation. NICs simply don't have the power to improve your gameplay that much. Only your ISP can do that, along with all the relevant Windows network configurations.
Always keep in mind that your internet connection comes from the outside to you, and this part of the network has to be optimal. Your PC or client is just one hop in the process, so you essentially have no control over the overall quality.
JimCarry
Post by JimCarry » 25 May 2024, 17:25
Unreazz wrote: ↑
25 May 2024, 15:03
i dont think you are right,if rss works its day and night difference.
Unreazz
Post by Unreazz » 25 May 2024, 19:12
JimCarry wrote: ↑
25 May 2024, 17:25
Unreazz wrote: ↑
25 May 2024, 15:03
What do you mean ? you can just simply activate it via powershell command. there is no reg edit needed
JimCarry
Post by JimCarry » 25 May 2024, 20:07
Unreazz wrote: ↑
25 May 2024, 19:12
JimCarry wrote: ↑
25 May 2024, 17:25
Unreazz wrote: ↑
25 May 2024, 15:03
do you even read what he type ? he dont even have it ?
Unreazz
Post by Unreazz » 25 May 2024, 23:44
JimCarry wrote: ↑
25 May 2024, 20:07
Unreazz wrote: ↑
25 May 2024, 19:12
JimCarry wrote: ↑
25 May 2024, 17:25
Unreazz wrote: ↑
25 May 2024, 15:03
i was not talking about him, i mean, what do you mean with "if rss works its day and night difference" why is it in your case then not activated ? or does it not working out for you ?
jassine
Post by jassine » 26 May 2024, 06:48
this is the result of this command: Get-SmbClientNetworkInterface, maybe my network card doesnt support RSS at all. But i saw people with same network card have it.
Capture d'écran 2024-05-26 124450.png (30.61 KiB) Viewed 17769 times
jassine
Post by jassine » 26 May 2024, 07:47
I just made a script to enable RSS, create RSSQueues, RSSProfile in case you dont have them:
Code: Select all
# Enable RSS
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001" /v "*RSS" /t REG_SZ /d "1" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001" /v "RSS" /t REG_SZ /d "1" /f
# Add RSS Parameter Description
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*RSS" /v "ParamDesc" /t REG_SZ /d "Receive Side Scaling" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*RSS" /v "default" /t REG_SZ /d "0" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*RSS" /v "type" /t REG_SZ /d "enum" /f
# Add RSS Enum Values
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*RSS\Enum" /v "0" /t REG_SZ /d "Disabled" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*RSS\Enum" /v "1" /t REG_SZ /d "Enabled" /f
# Set Number of RSS Queues
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001" /v "*NumRssQueues" /t REG_SZ /d "4" /f
# Add Number of RSS Queues Parameter Description
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*NumRssQueues" /v "ParamDesc" /t REG_SZ /d "Number of RSS Queues" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*NumRssQueues" /v "default" /t REG_SZ /d "4" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*NumRssQueues" /v "type" /t REG_SZ /d "enum" /f
# Add Number of RSS Queues Enum Values
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*NumRssQueues\Enum" /v "1" /t REG_SZ /d "1 Queue" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*NumRssQueues\Enum" /v "2" /t REG_SZ /d "2 Queues" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*NumRssQueues\Enum" /v "3" /t REG_SZ /d "3 Queues" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*NumRssQueues\Enum" /v "4" /t REG_SZ /d "4 Queues" /f
# Set RSS Profile
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001" /v "*RSSProfile" /t REG_SZ /d "4" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001" /v "RSSProfile" /t REG_SZ /d "4" /f
# Add RSS Profile Parameter Description
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*RSSProfile" /v "ParamDesc" /t REG_SZ /d "RSS load balancing profile" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*RSSProfile" /v "default" /t REG_SZ /d "1" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*RSSProfile" /v "type" /t REG_SZ /d "enum" /f
# Add RSS Profile Enum Values
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*RSSProfile\Enum" /v "1" /t REG_SZ /d "ClosestProcessor" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*RSSProfile\Enum" /v "2" /t REG_SZ /d "ClosestProcessorStatic" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*RSSProfile\Enum" /v "3" /t REG_SZ /d "NUMAScaling" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*RSSProfile\Enum" /v "4" /t REG_SZ /d "NUMAScalingStatic" /f
Reg Add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001\Ndi\Params\*RSSProfile\Enum" /v "5" /t REG_SZ /d "ConservativeScaling" /f
# both RSS and MSI are enabled
Reg add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001" /v "*RssOrMsi" /t REG_SZ /d "3" /f
# Specify CPUs that handle RSS: start cpu=BaseProcessorNumber, end cpu: MaxProcessorNumber, ie; [BaseProcessorNumber,MaxProcessorNumber]
Reg add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001" /v "BaseProcessorNumber" /t REG_DWORD /d "8" /f
Reg add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001" /v "*RssBaseProcNumber" /t REG_DWORD /d "8" /f
Reg add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001" /v "MaxProcessorNumber" /t REG_DWORD /d "14" /f
Reg add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001" /v "*RssMaxProcNumber" /t REG_DWORD /d "14" /f
#MaxRssProcessors: max 4 cores
Reg add "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4d36e972-e325-11ce-bfc1-08002be10318}\0001" /v "*MaxRssProcessors" /t REG_DWORD /d "4" /f
