Page 2 of 3
Re: low latency pc build help
Posted: 18 Aug 2024, 12:12
by zeko
Slender wrote: ↑
17 Aug 2024, 21:57
just buy good amd b650 / x670 board with realtek nic and usb 2.0 direct to cpu for your mouse only. msi/asus is good for amd. avoid gigabyte (always problem with bios). vrm there must be good if you want static oc your 9700x/x3d. open newegg amazon computeruniverse and find it.
Can you explain why usb 2.0?
Posted: 18 Aug 2024, 16:31
by Slender
zeko wrote: ↑
18 Aug 2024, 12:12
Slender wrote: ↑
17 Aug 2024, 21:57
better compatibility with usb 1.1 (1000hz) and usb 2.0 (2000hz+) mice.
usb inside cpu can fully bypass chipset (your mouse connect direct to cpu).
if you want try usb 2.0 now on intel you can get pci-e mcs9990 controller (true usb 1.1/usb 2.0) or use ports on front of you pc case (need check that GL 2.0 controller in usbtreeviewer). i know that gl chips have on z490/z590/z670/z790. but i dont find it on z170-z390.
Posted: 19 Aug 2024, 10:01
by jc41
Slender wrote: ↑
18 Aug 2024, 16:31
zeko wrote: ↑
18 Aug 2024, 12:12
Slender wrote: ↑
17 Aug 2024, 21:57
hello friend, do you have any idea which usb 2.0 onboard is the best if I am not buying an external pcie usb card? Now I am using Asus B760M motherboard, it comes with 4 USB 2.0 ports in a row, I can make sure that the mouse movement is different under each port (tested with only mouse and keyboard inserted), any suggestions for USB 2.0 port selection? Is It the port 4 closest to the motherboard (smoothest movement) or port 1(fastest response) away from the motherboard?
Posted: 13 Dec 2024, 09:43
by 144hZgod
AMD defender here :D ! So i can see that here ppl arent kinda amd fans, i dont wanna argue, i just wanna show my build on amd which i am using rn, and i will gladly accept any critique from intel fans!
Case: be quiet! Pure Base 500 FX, tempered glass, front ventilation
Motherboard: AORUS ELITE V1.x, AMD B650, WiFi 6E, Bluetooth 5.2, 3x M.2
Processor: AMD Ryzen 7 7700X (8C/16T, 4.5/5.4 GHz, Radeon™ Graphics integrated)
RAM: 32GB DDR5 @ 6000 MHz (Corsair Vengeance)
Graphics Card: ASUS RTX 4080 TUF Gaming, 16GB GDDR6X
SSD: Samsung 990 PRO, 2TB, PCIe Gen 4, 7450 MB/s
Power Supply: 1000W FSP HYDRO G PRO, PCIe 5.0, 80 PLUS Gold
Cooling: be quiet! PURE LOOP 2 FX 240mm AIO
i am a harcore pc gamerand this build works fine for me :D
Posted: 15 Dec 2024, 00:44
by naporitan
144hZgod wrote: ↑
13 Dec 2024, 09:43
:!: check out my topic :arrow: viewtopic.php?f=15&t=14025
Posted: 15 Apr 2025, 02:14
by slava1337
[/quote]
thoughts on PRIME B650M-A WIFI II? i will be puting 9700x on it
i know its entry level
my budget is tight to buy the 4070 s
Posted: 15 Apr 2025, 07:17
by Hyote
I want to add that laptops are most probably not resistant to EMI as many claim here but inputs feel smoother due to the increased number of power saving techniques. The other commenters are right though, go AMD or downgrade. Choose whether you want to have high fps and play with the feeling of VSync enabled or build a PC from earlier than 2018. Intel 10th gen is definitely affected because that's what I am on and my 6th gen PC used to be perfect with lightly tweaked Windows.
Posted: 30 Jun 2025, 20:21
by avengersid7
Slender wrote: ↑
12 Jun 2024, 07:51
7700 / 7700x / 9700x - best cpu
find any am5 board with cpu usb 2.0
memory is 7200c34 minimum (decrease timing and freq. to 6000 to be sure 1:1)
psu any 18avg.
vga any, but better to take manufacture is same like motherboard.
better to check qvl to be sure ram and vga is fully supported to your board.
avoid any intel.
Hi slender i hope u r doing well? your list is still valid for lowest input lag and latency.?9700x ,7600x cpu? please suggest something great,i have intel i7 14700kf ,its degraded and its driving me insane
Posted: 01 Jul 2025, 02:14
by Slender
avengersid7 wrote: ↑
30 Jun 2025, 20:21
Slender wrote: ↑
12 Jun 2024, 07:51
psu any 18avg.
avoid any intel.
you can go with 9700x / x3d both good cpu.
what is your psu?
Posted: 08 Jul 2025, 17:47
by donger
30 Jun 2025, 20:21
Contact the seller. Get your money back. Get 9800X3D. It's a known faulty piece of hardware. Don't get shafted by Intel. Every country has consumer laws to protect you. Use them.
