I fixed my input lag,network latency and Network lag for as much as i could atm.
JimCarry
Re: I fixed my input lag,network latency and Network lag for as much as i could atm.
- isthis.GIF (288.34 KiB) Viewed 4762 times
kamilff32
Thats interesting. Is the screen above accurate to how you did that ?Mighty wrote: ↑15 Aug 2024, 05:19all i did was going to "windows/system32/drivers" and manually installed mouhid and mouclass driversignatures. did that also with the RawAccel one as i play with mouse accelereration and now my mouse is super sensitive super responsive and theres no more imput lag, also recoil is a lot easier to control
And exacly where you get those driver signatures from.
timecard
If you wanted to try whatever he did, probably something like below.
Driver paths:
C:\Windows\System32\drivers\mouclass.sys (has digital signature)
C:\Windows\System32\drivers\mouhid.sys (doesn't have digital signature)
Right click the file (mouclass.sys) -> Go to digital signature tab -> click on the signature, press details -> view certificate -> certification path -> click Microsoft Windows Production PCA 2011 -> view certificate -> install certificate.
Mine expires in 2026-10-19 whereas his is old and expired already (2020) it seems so probably outdated windows or driver files.
Driver paths:
kamilff32
Soo the problem is theres no option to install it mine expired at 9/1/2022timecard wrote: ↑06 Sep 2024, 16:59If you wanted to try whatever he did, probably something like below.
Driver paths:
JimCarry
I just did what you wrote and i will show picture,but i think the thing i show in the screen above is something differenttimecard wrote: ↑06 Sep 2024, 16:59If you wanted to try whatever he did, probably something like below.
Driver paths:
- ffffGIF.GIF (195.63 KiB) Viewed 4442 times
Hyote
It's interesting because it seems to have made a positive difference.
Kal
how do i revert this?timecard wrote: ↑06 Sep 2024, 16:59If you wanted to try whatever he did, probably something like below.
Driver paths:
