Re: Poor quality audio from PC. What gives?
Posted: 20 Aug 2024, 04:44
It seems to measure something else then, I still think it's the magnetism of the radiator. There was an option to change the unit to milliGauss like your device shows, but all it seemed to do was change the decimal place; it said 7000-8000 mG instead of 750 mT.cybepine wrote: ↑19 Aug 2024, 07:38Yeah, it does give some indication that there is something. But I don't think it is very accurate. The numbers should not change.
I have very accurate measurement device, which is quite expensive. Magnetic field does not change, when I move it to close to the water heater radiator. The slight deviation is from my shaking hands. This is as it should be.
Also one cheap way is to use AM radio. The noise should not change.
If you decide to call the electrician you can ask him to use earth leakage current clamp meter on those water pipes (in bathroom also). I just repeat here as a precaution, do not touch bare metal parts on those pipes.
Your radiator looks identical to mine. The phone sensor reading jumped to red when I placed it on the darker exposed metal part behind the temperature knob where there was no paint. That part was definitely exposed grounded metal (no zap either, but I understand and appreciate what you're trying to warn about and why). Standing 1-2cm in front of the two water pipes must be the real source, because it gives me a very subtle feeling of tingling, but no actual tingle. The radiator doesn't do that. The pipes are about 20-30cm away from a wall outlet that also has the grounded TV/Radio coax sockets. I'm starting to think the pipes radiate something directly into that outlet and then it makes its way into the rest of the electrical system due to how close they are to each other constantly, but I can't explain how the interference can reach beyond 4-5 meters.
It's a building wider than it is tall, 4 apartments per floor and there are 3 floors with no elevator. In this case I don't think any of that really matters though.MegaMelmek wrote: ↑19 Aug 2024, 14:37Your issue is kinda same that i have…
Can you more discribe building you live in.
How many apartments are there,
how many entrance in the building if there is multiple entrance more than 2? (by entrance i dont mean back door)
What about lift is there or no?
Anyway, to whoever finds this post and themselves in a similar soup in the future:
Don't spend a penny on anything before you have tried to simply move your PC, guitar, amp, headphones or whatever the device is, further away from any radiators and windows; try it in a room that is farthest away from the source. This has been the best improvement yet but ultimately its effect depends on how far you can distance yourself and your devices from it, but probably doesn't fix it all the way even then.
