Yes, he needs News and Feeds constantly running in the background along with the latest eco-recommendations about lowering the refresh rate to conserve power. Windows 11 is trash and all the new Windows 10 versions are also straight downgrades from the older builds.
Presentation Model Optimization / Makes any game smoother
Re: Presentation Model Optimization / Makes any game smoother
my insane ghosting with 360hz/500+ fps
along with that, everything we already know, floating mouse, desync etc.
ps: offline with bots, in the game it's even worse
alienware aw2523hf
alienware aw2523hf
Syykfk wrote: ↑28 Oct 2024, 12:21I don't understand what you mean.
Do you mean, if you are using win11, then change Flags to 211 in the registry when opening mpo?
In addition, I am using win10, so what is the best suggestion for me in the optimization you mentioned? Thank you very much for your answer.
Don't think it's applicable for win 10 but for win11 I meant that you musn't do the old trick of disabling full screen optimizations and disabling mpo and instead deleting the flags folder for that game and it will reset the disabling optimizations trick and return it back to default which is fso + mpo which should be best.
You can also check your present mode with present mon and if it says hardware composed flip or hardware composed independent flip it should be correct.
InputLagger
that right a little.
1803 latest good windows with old like win7 timer.
All_AImCSGO
After months of procastinating I turned off high percision event timer and it fixed that issuie instantly. Just make sure you do it right.
Alright, I'll bite. What is your version of "correctly" doing timer settings?All_AImCSGO wrote: ↑12 Nov 2024, 00:42After months of procastinating I turned off high percision event timer and it fixed that issuie instantly. Just make sure you do it right.
