Page 2 of 3
Re: XL2546X users display scaling
Posted: 22 Feb 2025, 13:36
by Lev1n
Slender wrote:
06 Feb 2025, 04:24
Slender wrote:
12 Jan 2025, 16:42
jeffeh12133 wrote:
10 Jan 2025, 09:57
Slender wrote:
08 Jan 2025, 00:05
yes for firts 2h impressions that is best exp.
how to use that resolution correctly:
open sre.exe and delete all
open cru.exe and delete all resolutions exept 1080 60 360 / 1280x960
in all games you could see only 2 res.
in the earlier post though, you said the XL2546x+ display scaling is broken, can you explain how its broken?
Unfortunately, I don’t have xl2546s to show clearly, but the xl2566k has much worse overall picture clarity with display scaling; this blurriness doesn’t even correct sharpness 10. Although on the xl2546s I used the value 7. The menu has become so poor. The current resolution is not shown and you cannot find out whether display scaling is working or not. I would change this xl2566k to xl2546s if I had the opportunity.
Sorry, I really don’t have direct evidence that the new 2546x 2566k panels perform worse than the old panels. I'm only comparing the xl2546s and xl2566k, and comparing these two monitors the 2566 has a much less sharp image. Display Scaling worked perfectly on 2546s and even gave a crt feel at 800x600 in 1.6. I could play csgo at 1024x768 stretched and it was clear and crisp. At 2566k 1280x960 is not even close. Perhaps I got a bad panel in 2566 and a very good one in 2546s, I don’t know.
Im playing on 1080x1080 is there way to use this res with force display scaling? When i try add this to cru its crashing cs2.
Posted: 23 Feb 2025, 01:57
by Slender
Lev1n wrote:
22 Feb 2025, 13:36
Slender wrote:
06 Feb 2025, 04:24
Slender wrote:
12 Jan 2025, 16:42
jeffeh12133 wrote:
10 Jan 2025, 09:57
what your monitor?
Posted: 23 Feb 2025, 05:55
by Lev1n
Slender wrote:
23 Feb 2025, 01:57
what your monitor?
xl2546
Posted: 23 Feb 2025, 11:55
by Slender
Lev1n wrote:
23 Feb 2025, 05:55
Slender wrote:
23 Feb 2025, 01:57
what your monitor?
xl2546
send me your default (after reset) cru profile
(export)
Posted: 23 Feb 2025, 12:14
by Lev1n
Slender wrote:
23 Feb 2025, 11:55
Lev1n wrote:
23 Feb 2025, 05:55
Slender wrote:
23 Feb 2025, 01:57
what your monitor?
xl2546
(export)
I managed this to work. Its seems fine
https://imgur.com/9luvTHe
https://imgur.com/a/ilf5ljY
I hope im not doing something wrong :D
Posted: 24 Feb 2025, 13:53
by Slender
Lev1n wrote:
23 Feb 2025, 12:14
Slender wrote:
23 Feb 2025, 11:55
Lev1n wrote:
23 Feb 2025, 05:55
Slender wrote:
23 Feb 2025, 01:57
what your monitor?
xl2546
(export)
bro im need your default cru profile.
Posted: 24 Feb 2025, 14:06
by Lev1n
Slender wrote:
24 Feb 2025, 13:53
Lev1n wrote:
23 Feb 2025, 12:14
Slender wrote:
23 Feb 2025, 11:55
Lev1n wrote:
23 Feb 2025, 05:55
xl2546
(export)
https://imgur.com/a/8tV9Y1R
Posted: 24 Feb 2025, 14:08
by Slender
Lev1n wrote:
24 Feb 2025, 14:06
Slender wrote:
24 Feb 2025, 13:53
Lev1n wrote:
23 Feb 2025, 12:14
Slender wrote:
23 Feb 2025, 11:55
(export)
that is strange why displayport resolution using inside hdmi block.
can you "export" me your profile im try make it for you.
Posted: 25 Feb 2025, 05:06
by Lev1n
Slender wrote:
24 Feb 2025, 14:08
Lev1n wrote:
24 Feb 2025, 14:06
Slender wrote:
24 Feb 2025, 13:53
Lev1n wrote:
23 Feb 2025, 12:14
send you thru pm.
Posted: 04 Jun 2025, 19:43
by jeffeh12133
zeko wrote:
14 Feb 2025, 07:26
jeffeh12133 wrote:
06 Jan 2025, 02:47
Slender wrote:
09 Dec 2024, 00:05
zeko wrote:
07 Dec 2024, 16:57
Can anybody with xl2546x or any new zowie x monitor test their scalers? We remember k monitors had shitty and blurry display scaling, is it also the case for x monitors? With cru and true display scaling
xl2546s displayscaling is perfect.
xl2566k / xl2546k / X - broken.
but better use cru (native preset) + display scaling anyway.
can i ask how its broken? i just picked up a xl2546x+. i saw in the website "resolution preset list" file, that it has specified detailed timings for 1024x768 280hz, 1280x960 280hz, 1680x1050 280hz specifically for CS2 to work with display scaling. and when i tried it, it worked (desktop refresh rate was 1920x1080 280hz, ingame was 1024x768 279.996hz or something). also when i use display scaling and launch CS2 or alt tab on these specific resolutions, my game goes black for 2 seconds and actually allows me to adjust the Display Mode scaling settings in the OSD (between full, aspect, and 1:1 scaling) in the OSD when using display scaling. all three settings adjust the image appropriately.
with nvidia GPU scaling, it keeps to the default behavior that we all know of and displays lower resolutions as 1920x1080 280hz and doesnt allow switching of the Display Mode setting in OSD.
i checked the EDID using CRU/MonInfo and there are manually specified detailed timings for those 4:3 stretched style resolutions (1024x768, 1280x960, etc etc) that gamers like to use for CS2 or other competitive games. this leads me to believe that BenQ started supporting display scaling since apparently in the EDID these timings are specified (correct me if im wrong, but i dont think some of the older models had these timings and required GPU scaling). on top of that, i used display scaling for a bit and it works properly but i still like to use GPU. i might switch around and try display again though.
can you explain why its broken or what experience you had? for me it works fine but im just going based off a few hours of gameplay.
thanks mate <3 can you link that "resolution preset list? as far as I understand, I shoud enter those timings in cru, for example for 1024x768 for display scaling? so no cvt-rb / exact reduced or whatever
Sorry for the late response. Its on their website for whatever model you use. I didnt mean that it gave me what timings to specify for CRU, but i meant specific resolutions were applied into the monitors EDID automatically with the default EDID AND the monitor internally would state that its on 1280x960, 1024x768, or 1680x1050 at 280hz properly, based on whatever stretched res you use. The monitors info would reflect what res it uses, which means it would use true display scaling. The xl2546x+ has true display scaling when using 1280x960, 1024x768, and 1680x1050 all at 280hz which the previous xl2546k and before didnt have from what i read, you had to use gpu scaling for those.
As for the quality of the hardware scalar, i havent tested it much at all. All ive done since i got the monitor is use gpu scaling and no issues at all but im considering going back to display scaling since the idea of true display scaling, especially on stretched sounds appealjng
