The answer to that question requires a bit more context.
If talking from a gaming-only viewpoint:
The optimal way to ensure the best possible dynamic image quality (reducing stroboscopic effect & eliminating persistence blur) is to push the frame rate of the content & refresh rate of the display as much as possible.
As of Q1 2026, this crown takes the 27" QHD 540Hz → HD @ 720Hz WOLED panel.
Why WOLED over LCD? The G2G RT's are sufficiently fast enough (across the entire 0–255 range) to be more than enough to keep up with the refresh rate target (540Hz = 1,85185ms / 720Hz = 1,3889ms; while OLED's G2G RT are all comfortably ≤0,5ms)
Due to the scarcity of games where frame rate values are sufficiently high enough to be equal or greater than the aforementioned WOLED panel, the majority of games available to the market are played <300FPS.
For the general population, especially the competitive crowd, these frame rates aren't enough for our eyes to fully keep track of fast moving targets.
This is where LCDs with backlight strobing come into play.
On a good implementation (see my signature to find which models), you can achieve the “effective motion clarity” (Nvidia terminology) of a much higher refresh rate display at a much lower frame rate target.
E.g.: The XL2566K is able to achieve ~0,5ms MPRT when 360FPS@360Hz and using it's DyAc+ functionality.
The issue lies in the downside of backlight strobing & that is the flicker, which is a known & major eye strain contributor to quite a decent population size.
This is why I think that getting a high refresh rate OLED display & choosing content which can run at high frame rates (e.g.: desktop browsing, +500FPS games which I'm collecting into a list) are a much better long-term goal from a eye health standpoint than displays with backlight strobing.
Though, backlight strobing still has it's place... it's sad that it's always an afterthought in majority of models available :/
