I stream on Twitch and Discord, same input delay (increased a lot by normal). When i stop streaming, delay stills as usual in this forum users, but increases a lot only when streaming. I say that maybe cause of this delay has relationship with stress computer/console or Connection/ISP.
the only logical reson behind unexplained input lag and inaccurate sensitivity
spkii
Re: the only logical reson behind unexplained input lag and inaccurate sensitivity
- Z3CrosS
I think that i don't think
spkii
The thing is, people who streams on twitch, friends, etc... Normally dont have this delay added. I have it added x2 cause normalilly I have the "input delay problem EMI/Whatever" from base, so it increases a lot when streaming. That let you think if its electric problem or not.
- Z3CrosS
spkii
I tried with 3 different top gaming PCS, and repeat PS5. Some of my friends are streaming with lower tier PCS than mine, and with PS5 too and have no input delay and problems. They thing is they dont have the "Input delay EMI Whatever thing" from start, so mine increases a lot when streaming. Its not bottleneck cause tried with too many computers, monitors, mices, keyboards, Software OS.... Its related to this strange problem that all of us are finding a solution about. And when doing stream it increases a lot.Z3CrosS wrote: β10 Feb 2025, 03:00It's hardware issue, not psu not outlets have nothing to do with that, your so called "increase of input lag" have another proper naming, with load increase, PC latencies starts to x2 increases, it's a system bottleneck, and you cannot "fix" that. You have only two choices what to do - live with that and don't bother, or change PCs. Because if you continue to dancing with PC, you will just lose your time in vain.
But you can do everything you like, i just advise better & right thing to safe your time.
- Z3CrosS
spkii
Ok so the lag thing that we try to fix all users who has this problem on this forum its a Hardware issue....Z3CrosS wrote: β10 Feb 2025, 04:55I don't want to be rude, but i will use your words
If your friends Pcs/PS5 have better performance than yours, maybe they have Top PC, not you?
This issue that so corrupted called as "input lag" not exist and you cannot solve what is not exist.
Your issue located within hardware only and simple naming of it is not properly working PC, with increased latencies.
Interesting tho, how data flow happens in PC?
You as a user can affect PC only in 2 ways - damage PC or prevent damage. That's it. If you built PC and you see that PC performance not satsfy you, even if you use some options in bios and still the same - that's mean that something wrong with PC. Not more not less.
Other people who think that they can affect PC or "fix" this symptons, they do not understand almost anything, because they do not understand what exactly causing it, and how data flow happens within PC like devices.
Man, I tried with top competitive gamer Computers, i used to play competitive CS:Go and Valorant on a high rank, and i know this feel its not a "performance/Bad PC" problem. If that were the case, PS5 its the same for all users, why mine its Input lagging when stream and the others dont? Not about screen problem cause i tried with top tier screens that use Gamers (600β¬ gaming monitor, etc...)
- Z3CrosS
greenenemy
@spkii
Check ping wile streaming it could be bufferbloat creating ping spikes or even packet loss both can be perceived as input lag feeling. You can also try to limit your fps to free up some resources for the stream.
spkii
Ping is OK when streaming, FPS dont dropes lower than 230-240fps on CS2, Valorant or Marvel Rivals... idkgreenenemy wrote: β10 Feb 2025, 08:39@spkii
