HIGH % YOUR InputLag/HitReg IS NETWRK RELATED.
bladeZ
Re: HIGH % YOUR InputLag/HitReg IS NETWRK RELATED.
Post by bladeZ » 27 Feb 2025, 23:18
Hyote wrote:
27 Feb 2025, 07:19
I've been experimenting with some settings that needed to be disabled in gpedit and now I have massively reduced desync. The last two that disable cmd and regedit should be set before playing games and reenabled when needed. There is a potential for placebo as always but the reason I'm sharing these is because I notice a huge change in online games which have been nearly unplayable until now.
Computer Configuration, Administrative Templates, System:
Display highly detailed status messages - Disabled
Computer Configuration, Administrative Templates, Windows Components, Event Logging:
Enable Protected Event Logging - Disabled
Computer Configuration, Administrative Templates, Windows Components, Event Viewer:
Events.asp program - Disabled
User Config, Admin Templates, System, Scripts:
Run legacy logon scripts hidden - Enabled
Run logon scripts synchronously - Disabled
Run Windows PowerShell scripts first at user logon, logoff - Enabled
User Config, Admin Templates, System:
Prevent Access to the command prompt - Enabled ; Disable the command prompt script processing also - Yes
Prevent Access to registry editing tools - Enabled ; Disable regedit from running silently - Yes
i just applied your recommended settings my gameplay feels awesome paired with this, i highly suggest others to try this along with disabling MPO + Enabling Exclusive Fullscreen and testing the network buffering setting inside of your game settings.
GPU: RTX 3060 12gb (currently waiting for 5060ti upgrade)
CPU: Ryzen 5800X3d
RAM: CL12 3000Mt
MONITOR: ZOWIE XL2566X+ 400HZ Fast Tn
NZXT C850 WATT PSU
JimCarry
Post by JimCarry » 28 Feb 2025, 11:28
bladeZ wrote:
27 Feb 2025, 23:18
Hyote wrote:
27 Feb 2025, 07:19
are you talking about "Buffering to smooth over packet loss" ? in cs2 options menu ?
themagic
Post by themagic » 28 Feb 2025, 12:58
JimCarry wrote:
28 Feb 2025, 11:28
bladeZ wrote:
27 Feb 2025, 23:18
Hyote wrote:
27 Feb 2025, 07:19
don't sure if placebo or not but i apply this all without even restart and played some CS2 DM and it was much better...
but i am right now experementing much with internet and network settings and VPN and more...cause i am right now 100% sure that all my suffering is because of ISP's and there bad Configuration or something else rly wrong going there with gaming packets and which causes all the hell experience here in whole Location and even in 2 Apartments which i already tried here...my online gaming since many Years already...
gonna report soon my findings too cause i find something interesting yesterday about valorant and hitreg but i always get kicked out of Matches after 3-4 minutes with different VANs and Vals error from 84, 5 and -102...even got one time a Temp Ban message but which was only for 1 minute suspend duration lol and could don't login and start game...very very fucking weird shit. :lol:
but hitreg and peekers advantage and everything else was amazing during this 3-4 minutes gameplays...very playable and without much bullshit.
JimCarry
Post by JimCarry » 28 Feb 2025, 18:23
themagic wrote:
28 Feb 2025, 12:58
JimCarry wrote:
28 Feb 2025, 11:28
bladeZ wrote:
27 Feb 2025, 23:18
Hyote wrote:
27 Feb 2025, 07:19
should i run this with gpedit.msc via run or should i use PolicyPLus https://github.com/Fleex255/PolicyPlus
Hyote
Post by Hyote » 01 Mar 2025, 01:17
I just use normal gpedit but that should work as well, whichever you like more.
spkii
Post by spkii » 01 Mar 2025, 04:01
themagic wrote:
28 Feb 2025, 12:58
JimCarry wrote:
28 Feb 2025, 11:28
bladeZ wrote:
27 Feb 2025, 23:18
Hyote wrote:
27 Feb 2025, 07:19
You trying with VPN?? its working better?
themagic
Post by themagic » 01 Mar 2025, 09:19
spkii wrote:
01 Mar 2025, 04:01
themagic wrote:
28 Feb 2025, 12:58
JimCarry wrote:
28 Feb 2025, 11:28
bladeZ wrote:
27 Feb 2025, 23:18
yes. i am playing around with expressvpn right now but gonna or want to try purevpn soon...
"PureVPN Port Forwarding — PureVPN is only premium VPN that offers a port forwarding add-on with high-end encryption."
I believe that NAT type or Firewall and CGNAT from my ISP's here are the reason of all my suffering...maybe...cant tell right now 100% if that the reason...
On my LTE router i get Symmetric Nat and on my DSL i get Port-restricted cone NAT....if doing test on this site: https://www.checkmynat.com
but something weird happens with my gaming packets and i figured out that expressvpn and with enabled tunnel-split option that things getting much better for me...
but i get always kicked out matches in valorant with that and different van errors....
JimCarry
Post by JimCarry » 01 Mar 2025, 10:06
Hyote wrote:
01 Mar 2025, 01:17
ok thanks i will try i will apply it then restart pc and test.
bladeZ
Post by bladeZ » 02 Mar 2025, 04:02
themagic wrote:
01 Mar 2025, 09:19
spkii wrote:
01 Mar 2025, 04:01
themagic wrote:
28 Feb 2025, 12:58
JimCarry wrote:
28 Feb 2025, 11:28
have you tried removing the ethernet cable from pc and using the wifi connection only? try that and see if you can get a similar effect as with vpn (dont forget to disable power saving from wifi network settings). but if anything it is impressive that using a vpn is helping you with this issue ive never heard of that, insane finding tbh
CPU: Ryzen 5800X3d
RAM: CL12 3000Mt
NZXT C850 WATT PSU
JimCarry
Post by JimCarry » 02 Mar 2025, 17:07
Hyote wrote:
27 Feb 2025, 07:19
I apply them and Win32PrioritySeparation set to decimal 42,and i think its better then before, but what if i want to use regedit for example, should i make the last tho options to "Not Configured" and then restart pc so i can use regedit and then disabled it and restart again ?
