Page 2 of 3
Re: What newer PC parts have lower input lag?
Posted: 22 May 2025, 14:59
by Hyote
Inputlagg3r wrote: ↑
22 May 2025, 13:36
Hyote wrote: ↑
18 May 2025, 20:34
18 May 2025, 17:31
Slender wrote: ↑
14 Apr 2025, 08:54
Intel is not worth considering buying at all until they give up their e-cores, which spoil everything. In addition, AMD has lower c2c latency and they have USB directly in the processor, what could be better for a mouse than bypassing the chipset?
The last good Intel are 9700k and 10700k.
I got a 10900K, 3080, def feels better than every ryzen ive had, ive disabled SOOO much though, power settings made a big difference. Esp USB related ones, i need more tips though, ive disabled alot in BIOS too
Can you give some more tips in tweaks?
My github has a collection of like everything ever and has been tested on a 10850k.
Link? Tried finding it, but couldnt
https://github.com/Hyyote/files-
The .bat files have two lines with ForceRefreshRate set to my preferred refresh rate, that has to be changed to your own.
Otherwise (I think) everything is configured to be the best generally.
Posted: 23 May 2025, 00:58
by n1ghtik
Hyote wrote: ↑
22 May 2025, 14:59
22 May 2025, 13:36
Hyote wrote: ↑
18 May 2025, 20:34
18 May 2025, 17:31
one million event viewer errors desync system final pack
Posted: 23 May 2025, 03:14
by Hyote
n1ghtik wrote: ↑
23 May 2025, 00:58
Hyote wrote: ↑
22 May 2025, 14:59
22 May 2025, 13:36
Hyote wrote: ↑
18 May 2025, 20:34
What Event Viewer?
Posted: 08 Jul 2025, 05:03
by donger
Slender wrote: ↑
13 Apr 2025, 02:41
1200w psu, 9700x, asus x870-a strix, rtx 4060ti+ / 9070 xt
Can you explain to me why you harm wallets of users of this forum recommending 1200W PSUs for PCs drawing 600W???
Posted: 08 Jul 2025, 05:17
by Slender
donger wrote: ↑
08 Jul 2025, 05:03
Slender wrote: ↑
13 Apr 2025, 02:41
it fix desync
Posted: 08 Jul 2025, 08:28
by 1000WATT
donger wrote: Can you explain to me why you harm wallets of users of this forum recommending 1200W PSUs for PCs drawing 600W???
It is easier to buy a 1500 W titanium power supply once. And forget about buying a new one for 30 years. Forget about voltage imbalances 5v 12v. Forget about the fact that it heats up, since the fan will not spin due to low load. The capacitors on the motherboard will not receive increased current, since there are no 5v dips. Such power supplies will have effective protection against short circuits guaranteed. I can continue to describe the advantages for a long time.
kyube wrote: psu: Corsair AX1600i (GaN PSU)
I'm mad at you. Now I want a power supply with gallium nitride transistors. :lol:
Posted: 08 Jul 2025, 10:08
by donger
Slender wrote: ↑
08 Jul 2025, 05:17
donger wrote: ↑
08 Jul 2025, 05:03
Slender wrote: ↑
13 Apr 2025, 02:41
it fix desync
oh so you are here to troll, got you bro
Posted: 08 Jul 2025, 10:11
by donger
1000WATT wrote: ↑
08 Jul 2025, 08:28
Or you know. You could do the exact same with 750-850W one. 1200-1500 is literally a waste of money. It's better to replace every 10 years because that's what manufacturers designed them to operate long for. Unless you open them and inspect crucial parts(like capacitors) after the warranty is over.
Literally not a single one of those 'advantages' matters unless you have autism but sure keep on going. You would make a great PSU seller at Walmart to clueless sheep.
Posted: 08 Jul 2025, 16:53
by Slender
donger wrote: ↑
08 Jul 2025, 10:08
Slender wrote: ↑
08 Jul 2025, 05:17
donger wrote: ↑
08 Jul 2025, 05:03
Slender wrote: ↑
13 Apr 2025, 02:41
it fix desync
viewtopic.php?f=24&t=13054
don't talk to me like that, bro
Posted: 08 Jul 2025, 16:57
by donger
Slender wrote: ↑
08 Jul 2025, 16:53
donger wrote: ↑
08 Jul 2025, 10:08
Slender wrote: ↑
08 Jul 2025, 05:17
donger wrote: ↑
08 Jul 2025, 05:03
it fix desync
i am not reading that schizo garbage
