broken scaling cause of heavy/floating mouse, desync, heavy car bug, input lag etc
Watchdog
Re: strange behavior of the monitor and NVIDIA!
Post by Watchdog » 02 May 2025, 07:22
So you set the scaling mode in NVIDIA to GPU and override scaling mode ticked on?
naporitan
Post by naporitan » 03 May 2025, 02:40
Watchdog wrote: ↑
02 May 2025, 07:22
Simply put, my monitor has broken scaling.... this monitor is not for gaming, even though it is 240 hertz....
naporitan
Post by naporitan » 03 May 2025, 02:57
It's impossible to describe exactly how you feel when playing, but there is a heavy model and mouse effect and the reason for this is broken monitor scaling!
people, buy functioning monitors!
Don't know what we're talking about? This user recorded a very high quality video!
https://youtu.be/v8OZsCPhMC0
P.S. the problem is not electrical interference, EMI, etc.
how do I know which monitor is working?
I will show you benq zowie and asus as examples!
1. benq zowie xl2546
the monitor must have a driver!
Screenshot 2025-05-03 164415.png (31.04 KiB) Viewed 6573 times
and most importantly working scaling!
Screenshot 2025-05-03 164622.png (162.96 KiB) Viewed 6573 times
2. ASUS ROG Strix XG259QN
driver
Screenshot 2025-05-03 164902.png (18.36 KiB) Viewed 6573 times
:!: :!: :!: viewtopic.php?f=10&t=14611&start=80#p116226
naporitan
Re: broken scaling cause of floating mouse
Post by naporitan » 03 May 2025, 08:52
XL2411P
(if anything you should not buy this monitor in 2025 because the monitor is officially unsupported for a very long time and it is not known if the monitor scaling works properly with new GPU drivers and on new windows systems!!!!)
Screenshot 2025-05-03 224629.png (111.42 KiB) Viewed 6486 times
Back in the old-school days these resolutions were trending, I remember some hardcore players recommended playing at 120 hertz on this monitor, but I didn't understand why and always played at 144 hertz and had a bad gaming experience :cry:
Screenshot 2025-05-04 165216.png (410.4 KiB) Viewed 6198 times
naporitan
Post by naporitan » 03 May 2025, 09:47
I do not recommend buying these two monitor models XL2540K/XL2546K as they have only one resolution at which there will be no scaling bug.
I wrote this just in case since there are pro gamers who advertise these monitor models, but these models are not for true competitive gamers!!!
Screenshot 2025-05-03 234318.png (96.52 KiB) Viewed 6462 times
n1ghtik
Post by n1ghtik » 03 May 2025, 12:17
application can store information about its scaling, checking the box for "override the scaling mode" is not bad
you can experiment with EDID and native resolution in CRU, I have a 27 inch msi monitor which has a crappy scaling implementation. I managed to get the screen scaling correct, display gives the gpu the unscaled image and gpu stretches it to full screen.
Also in cs2 I faced a problem that after alt-tab scaling broke, and I got a soapy blurry image. To fix this you need to change the value of the variable “setting.fullscreen_min_on_focus_loss” to “1” in the .txt file of the video game settings, the path to this file Steam/userdata/\(userId)/730/local/cfg
naporitan
Post by naporitan » 03 May 2025, 12:29
n1ghtik wrote: ↑
03 May 2025, 12:17
It's not a solution to the problem. The problem is on another level.
On such monitors it is impossible to fix it.... It is necessary to buy a monitor that is in good working order before buying a monitor, check the manual!!!!!!
Post by Slender » 03 May 2025, 14:17
xl2546s and xl2566k is broken?
2546s in my case was very clear, and display scaling vs gpu scaling difference was noticeable. Even on 10 clarity, xl2566k is worse than xl2546s on 7.
but, xl2566k has preset 768 and 960. I just remove all resolutions except 1080 and 960. and I can use scaling (no scaling) and everything will scale correctly
Post by Slender » 03 May 2025, 14:31
monitor and gpu compatibility?
naporitan
Post by naporitan » 03 May 2025, 15:12
Slender wrote: ↑
03 May 2025, 14:17
No.
If I had a choice between xl2546s and xl2566k, I would choose xl2546s.
xl2546s
Screenshot 2025-05-04 050834.png (58.32 KiB) Viewed 6316 times
xl2566k
Screenshot 2025-05-04 051100.png (95.85 KiB) Viewed 6316 times
