Page 2 of 11
Re: strange behavior of the monitor and NVIDIA!
Posted: 02 May 2025, 07:22
by Watchdog
So you set the scaling mode in NVIDIA to GPU and override scaling mode ticked on?
Posted: 03 May 2025, 02:40
by naporitan
Watchdog wrote: ↑02 May 2025, 07:22
Simply put, my monitor has broken scaling.... this monitor is not for gaming, even though it is 240 hertz....
Posted: 03 May 2025, 02:57
by naporitan
It's impossible to describe exactly how you feel when playing, but there is a heavy model and mouse effect and the reason for this is broken monitor scaling!
people, buy functioning monitors!
Don't know what we're talking about? This user recorded a very high quality video!
https://youtu.be/v8OZsCPhMC0
P.S. the problem is not electrical interference, EMI, etc.
how do I know which monitor is working?
I will show you benq zowie and asus as examples!
1. benq zowie xl2546
the monitor must have a driver!
- Screenshot 2025-05-03 164415.png (31.04 KiB) Viewed 6585 times
and most importantly working scaling!
- Screenshot 2025-05-03 164622.png (162.96 KiB) Viewed 6585 times
2. ASUS ROG Strix XG259QN
driver
- Screenshot 2025-05-03 164902.png (18.36 KiB) Viewed 6585 times
viewtopic.php?f=10&t=14611&start=80#p116226
Re: broken scaling cause of floating mouse
Posted: 03 May 2025, 08:52
by naporitan
Posted: 03 May 2025, 09:47
by naporitan
I do not recommend buying these two monitor models XL2540K/XL2546K as they have only one resolution at which there will be no scaling bug.
I wrote this just in case since there are pro gamers who advertise these monitor models, but these models are not for true competitive gamers!!!
- Screenshot 2025-05-03 234318.png (96.52 KiB) Viewed 6474 times
Posted: 03 May 2025, 12:17
by n1ghtik
application can store information about its scaling, checking the box for "override the scaling mode" is not bad
you can experiment with EDID and native resolution in CRU, I have a 27 inch msi monitor which has a crappy scaling implementation. I managed to get the screen scaling correct, display gives the gpu the unscaled image and gpu stretches it to full screen.
Also in cs2 I faced a problem that after alt-tab scaling broke, and I got a soapy blurry image. To fix this you need to change the value of the variable “setting.fullscreen_min_on_focus_loss” to “1” in the .txt file of the video game settings, the path to this file Steam/userdata/\(userId)/730/local/cfg
Posted: 03 May 2025, 12:29
by naporitan
n1ghtik wrote: ↑03 May 2025, 12:17
It's not a solution to the problem. The problem is on another level.
On such monitors it is impossible to fix it.... It is necessary to buy a monitor that is in good working order before buying a monitor, check the manual!!!!!!
Posted: 03 May 2025, 14:17
by Slender
xl2546s and xl2566k is broken?
2546s in my case was very clear, and display scaling vs gpu scaling difference was noticeable. Even on 10 clarity, xl2566k is worse than xl2546s on 7.
but, xl2566k has preset 768 and 960. I just remove all resolutions except 1080 and 960. and I can use scaling (no scaling) and everything will scale correctly
Posted: 03 May 2025, 14:31
by Slender
monitor and gpu compatibility?
Posted: 03 May 2025, 15:12
by naporitan
Slender wrote: ↑03 May 2025, 14:17
No.
If I had a choice between xl2546s and xl2566k, I would choose xl2546s.
xl2546s
- Screenshot 2025-05-04 050834.png (58.32 KiB) Viewed 6328 times
xl2566k
- Screenshot 2025-05-04 051100.png (95.85 KiB) Viewed 6328 times
