HungaryChristophSmaul1337 wrote: ↑07 Jun 2025, 03:32Thanks! A couple more questions (which I've updated in my original post as well): Where (roughly) are you from? Does your version of the "3-prong" plug enforce polarity? Could you rotate the plug in the socket by 180°?Hyote wrote: ↑07 Jun 2025, 01:59I used to have all my devices plugged into different outlets, but after trying this my monitor's image quality seems to have improved. The mouse feels more consistent as well but I wouldn't call it better, because I used to separate my cables and plug them into different outlets each, but this works as well.
Also, do you know how your room is wired? Some regions of the world daisy-chain the outlets instead of running separate wires to them. In my case, I have a little distribution panel inside the wall in this room, and all outlets are on a separate wire run. However, it might be that your room gets one "main" wire run to an outlet straight from the breaker box and then just daisy-chains the other outlets. Do you happen to know what kind of installation is present?
Polarity is not enforced
Yes, I can rotate the plug
I don't know almost anything about electricity but it's almost certain to be the way you mentioned straight from the breaker box.
