Help, there is no smoothness in games and strange weapon recoil.
DanGamesTwitch
Re: Help, there is no smoothness in games and strange weapon recoil.
- kyube
You are only confirming what I've told you in the beginning of your OP.DanGamesTwitch wrote: ↑24 Jun 2025, 16:23I bought a new Benq xl2566x+ monitor and bought new RAM as soon as I connected the new monitor for the first 5 minutes everything was too smooth, I can't describe it in words, the entire desktop was like alive as soon as I restarted the PC everything instantly became the same as on the old monitor, there is no smoothness and a feeling of a drop in fps, but the fps is 800 stable
You have a hardware instability issue, as do a majority of users here without knowing
There's no other way around it.
You need to give us more concrete information on what testing you've conducted and whether you've even conducted any testing.
Start by telling us which BIOS settings you've changed.
Showing a ZenTimings screenshot with your EXPO profile or run EXPO disabled for a while on a new installation
These are good 1st steps for troubleshooting.
This is, of course, assuming we're not talking about external factors (psychological, physiological)
At this point, with the sheer amount of similarly titled threads (all from CS2 players, funnily enough), I think users here should stick to ECC RAM (+ ASUS, Asrock or GB AM5 board) and stop taking any mind-altering medications (if they're doing so)....
Asesino34
In NVIDIA, create a custom resolution, 1920 x 1080, and set it to polarity + + (plus plus) or + - (plus minus), save and apply. Since you just bought a new monitor and it got fixed until reboot, maybe for some strange reason it's forcing a default polarity of - - (minus minus), and that negative-negative setting makes everything look weird and choppy. It's just a suggestion—hopefully it helps.DanGamesTwitch wrote: ↑07 Jun 2025, 17:08Hello everyone, I have written multiple times but have not received a single comment.
I don't know what's happening or what to do.
I replaced my PC three times in hopes of fixing the issue.
My previous setups included:
- Intel Core i5-13600KF
- AMD Ryzen 5 7600X
- AMD Ryzen 7 9800x3d
I changed the processor, motherboard, power supply, case, water cooling system, and graphics card.
However, I did not change the RAM or monitor.
My current PC configuration:
- Gigabyte B650 Gaming X AX V2 motherboard
- AMD Ryzen 7 9800x3d processor
- NVIDIA RTX 4090 graphics card
- Team Group DDR5 32GB (2x16GB) 6000MHz (PC-48000) T-Create Expert CL38 1.25V
- BenQ XL2546 monitor
montech titan gold 1000
In games, I get high FPS but no smoothness in the image. The recoil is exaggerated, twitchy, and unstable—completely lacking smoothness and softness in the picture. There are no lags or freezes; only the smoothness and visual softness are affected.
I have tried all tweaks from five different people who configured Windows and BIOS for me, but there is no difference.
For example, in CS2, I get stable 750-800 FPS on a 240Hz monitor with everything set up correctly and the game fully configured. But the image feels like my FPS is only around 100–120. When I try to control recoil by pulling down the mouse, bullets don't respond properly—they seem uncontrollable. Sometimes everything hits perfectly, especially at night.
My router is Keenetic Ultra KN-1810 with internet speed of 1000 Mbps.
I wonder if the internet connection could cause unstable visuals or strange recoil behavior. Also, could the issue be related to RAM or the monitor? Honestly, I don't know what else to do. Please help me!
And just to clarify, this problem isn't only in CS2; it occurs on the desktop and in other games as well. There is high FPS everywhere, but it feels like there's not enough FPS or that something is off with the smoothness.
I understand that this could possibly be electrical or abnormal input lag, but I live in new, expensive houses, and honestly, I don't know if that's the case.
I'll mention that I'm writing this message through a translator, so it might affect the accuracy. If you need precise information, someone from Russla can contact me privately via message or Discord (dangames).
AHAHAHAHAHAHAHAHAHAHAHAHAHAHAHHAAHAHHAHAHAHAHAH
- kyube
Polarities are a relic of CRT-era displays, they do not impact modern LED LCD nor OLED displays.Asesino34 wrote: ↑24 Jun 2025, 18:13In NVIDIA, create a custom resolution, 1920 x 1080, and set it to polarity + + (plus plus) or + - (plus minus), save and apply. Since you just bought a new monitor and it got fixed until reboot, maybe for some strange reason it's forcing a default polarity of - - (minus minus), and that negative-negative setting makes everything look weird and choppy. It's just a suggestion—hopefully it helps.
This has been confirmed by ToastyX and Chief many times... Source: viewtopic.php?t=4636#p35998
Stop it with the nonsense already.
Asesino34
If I'm telling you to do it, it's because it can actually happen. How can you give an opinion on something you haven’t even tested, just by linking a topic from someone else, without trying it yourself? I’m saying it because I tested it for several days a few months ago — if you set double negative polarity, your Hz get messed up. But I don't even know why I'm replying, since based on your answer, I can already tell you don’t even know it's possiblekyube wrote: ↑24 Jun 2025, 18:24Polarities are a relic of CRT-era displays, they do not impact modern LED LCD nor OLED displays.Asesino34 wrote: ↑24 Jun 2025, 18:13In NVIDIA, create a custom resolution, 1920 x 1080, and set it to polarity + + (plus plus) or + - (plus minus), save and apply. Since you just bought a new monitor and it got fixed until reboot, maybe for some strange reason it's forcing a default polarity of - - (minus minus), and that negative-negative setting makes everything look weird and choppy. It's just a suggestion—hopefully it helps.
- kyube
Why would I trust your opinion over the likes of ToastyX and Chief Blurbusters?
The former is the creator of CRU and the latter has decades of knowledge in this industry.
I don't care about your subjective "feel" ramblings, they're nonsensical.
I can easily give an opinion on something I haven't tested, because you're a layman and you're placeboing yourself that changing polarity does anything in regards to total system latency.Asesino34 wrote: ↑24 Jun 2025, 21:04How can you give an opinion on something you haven’t even tested, just by linking a topic from someone else, without trying it yourself? I’m saying it because I tested it for several days a few months ago — if you set double negative polarity, your Hz get messed up. But I don't even know why I'm replying, since based on your answer, I can already tell you don’t even know it's possible
Why would I trust your opinion compared to application software developers who know the inner workings of the entire HW-to-display pipeline?
Absurd.
DanGamesTwitch
Please do not write here at all. You don't even understand what you're writing about. What's the point of CS2? I generally don't experience smooth visuals at 240Hz and 240 FPS or even 800 FPS—there's no difference at all.kyube wrote: ↑24 Jun 2025, 16:38You are only confirming what I've told you in the beginning of your OP.DanGamesTwitch wrote: ↑24 Jun 2025, 16:23I bought a new Benq xl2566x+ monitor and bought new RAM as soon as I connected the new monitor for the first 5 minutes everything was too smooth, I can't describe it in words, the entire desktop was like alive as soon as I restarted the PC everything instantly became the same as on the old monitor, there is no smoothness and a feeling of a drop in fps, but the fps is 800 stable
You're talking about some settings, but I've been dealing with this issue for 3-4 years, buying increasingly expensive graphics cards and processors. I also have professional BIOS and Windows tuners who do this for a living. I have many friends in esports for Apex, CS, and Overwatch.
They all tell me to leave this cursed apartment and move somewhere else. And you keep suggesting some EXPO profiles and tests to send you. First, read what I wrote in the post. It really irritates me when I say everything is perfectly configured on my end, and you start talking about profiles.
I have four computers with different builds and components, all configured differently, but the problem is the same everywhere: no smooth image. I thought maybe it was the monitor, but no—I bought a BenQ XL2566K+ with 400Hz. The first five minutes were great, then suddenly everything went downhill.
The issue is 100000000000000% related to electricity—either in the transformer box or perhaps in faulty elevators.
- Slender
Kuobe, even a poorly configured PC will work flawlessly at 60fps/60hz in a place where there are no problems with monitor smoothness. Enough talk about how bad settings are the root cause of all the problems people have here. This certainly makes sense, but not as much as if everything worked initially from the first seconds of the Windows circle animation.
- kyube
You have no authority to order me around and tell me what to do.DanGamesTwitch wrote: ↑26 Jun 2025, 23:35Please do not write here at all. You don't even understand what you're writing about. What's the point of CS2? I generally don't experience smooth visuals at 240Hz and 240 FPS or even 800 FPS—there's no difference at all.
I've decided to give you an advice (for you & others who browse these forums to see) and offer you support, you're free to ignore it.
Let's remind ourselves about your OP words:
It isn't me who has written that he has issues in CS2. I don't understand the point of your "What's the point of CS2" question, when you're the one who mentioned it first.For example, in CS2I get stable 750-800 FPS on a 240Hz monitor with everything set up correctly and the game fully configured. But the image feels like my FPS is only around 100–120. When I try to control recoil by pulling down the mouse, bullets don't respond properly—they seem uncontrollable. Sometimes everything hits perfectly, especially at night.
“Professional Windows tuners”DanGamesTwitch wrote: ↑26 Jun 2025, 23:35You're talking about some settings, but I've been dealing with this issue for 3-4 years, buying increasingly expensive graphics cards and processors. I also have professional BIOS and Windows tuners who do this for a living. I have many friends in esports for Apex, CS, and Overwatch.
The duration of you "dealing with the issue" is irrelevant to the subject.
Why are you scared of extensively writing out how you've configured your HW & SW stack? I've seen what these clueless "professionals" do. They scam ignorant users like you for money. They scam even bigger fishes, such as tournament organizers, let alone users like you.
Who are you to judge what's "perfectly configured"? I'm not sure under what pretense you assume this. Who told you that it's "perfect"? You? What data supports this claim that it's "perfectly configured"?DanGamesTwitch wrote: ↑26 Jun 2025, 23:35They all tell me to leave this cursed apartment and move somewhere else. And you keep suggesting some EXPO profiles and tests to send you. First, read what I wrote in the post. It really irritates me when I say everything is perfectly configured on my end, and you start talking about profiles.
If it's so "perfect". why not share your "perfection" to us?
“Smoothness” is 95% about framepacing (even this is a underestimated percentage), 5% about external variables (networking , electricity, psychological, physiological)DanGamesTwitch wrote: ↑26 Jun 2025, 23:35I have four computers with different builds and components, all configured differently, but the problem is the same everywhere: no smooth image. I thought maybe it was the monitor, but no—I bought a BenQ XL2566K+ with 400Hz. The first five minutes were great, then suddenly everything went downhill.
It's about minimizing latency fluctuations, all of which are graphable with PresentMon & similar tools.
It doesn't matter how many different builds & components you've had, the possibility of applied settings being detrimental to latency every time is present until you prove otherwise.
All of those issues you're describing can be rooted in electricity & networking.
However, until you've given more concrete evidence that your HW & SW is set up correctly, all of these assumptions are moot.
Stop chasing Casper.
- Slender
If you've set everything up, why are you still here?
