Re: Ground fault or something else
Posted: 17 Jun 2025, 11:29
I've already tried this in some what "way".Slender wrote: ↑17 Jun 2025, 02:21did he find out where the static charge on his body came from? Even if so, touching a grounded PC or grounding contact should remove the charge. In fact, connecting the body to ground should solve such problems, but it does not. The body does two things: conducts and absorbs current. if you consider the body the main source, isolate your feet from the floor and use all wireless devices.Inputlagguy wrote: ↑16 Jun 2025, 21:14The shower thing; may because of ur skin becoming very dry after showers.Rallaz wrote: ↑16 Jun 2025, 04:29Yes, your describing many things I've also noticed myself.Inputlagguy wrote: ↑13 Jun 2025, 00:26Yep. I’ve noticed static/grounding directly affect my gameplay many many times.
Playing with socks and shoes on vs barefoot makes a difference. Touching the monitor sometimes puts it in god mode, absolutely no desync and buttery smooth gameplay.
Putting down the controller for 10-15 seconds and picking it back up seems like it simply resets the charge and gives u better gameplay until u start shooting/driving around in ur case.
Interesting I’ve noticed the same thing that cotton (which causes less static) makes the gameplay worse vs causing more static with stretchy elastic like clothes. Weird
I still cannot get around the fact that i can’t get good gameplay literally *anywhere* i go. Even where my friends play amazingly well effortlessly. I have about 2 minutes of good gameplay and i can feel the desync start to settle in.
Our body must react differently than other people to static charges or something. I’ve been shocking my cats sometimes when we touch. I have no idea i really barely play much anymore, it’s too stressful.
I either sit in the firing range for hours testing things or just jump into ranked with like a 5-10% rate of good gameplay out of the whole session.
There’s no use in playing anything competitive with this problem, especially games that are fast paced and where aim/micro movements matter the most. U are at a huge disadvantage(which seems like an understatement really). More like a handicap
While I tho use this "wiring" trick it causes overall much less delay by having cables wired from the monitor stand or pc-case to the waterborne-element.
Somehow it makes a lot of difference.
Which is why it leads me to some grounding issue.
But I cannot wrap my head around if its a device causing this issue itself since I've like many others tried multiple setups of mice, kb, monitors etc.
And at some locations the problem doesn't even occur with my regualar stuff.
But my conclusion is that some how it's bound to static eletricity and its something either "we" build up because of something.
I don't have any real idea.
It's very weird.
Something that's not for none-believers to read now:
I don't shower for like 2-3 days the problem becomes SOMEHOW less noticeable.
If I shower than the next day its like I'm resetting it back to square-one xD.
Just some odd patterns I've noticed, even tried showering every day and that gives me a consistent of worsen gameplay.
Its just extremely weird.
I've tried using USB-fans connected to my pc and aiming that fan to blow air on the wires for mouse and kb, and that seems to really affect something.
It's like a "clock" of like 2-minutes good, 2 minutes bad kinda pretty much. But the thing is that it's like stuck than between the "worse state and the best state".
Not super bad and not super good.
There was a post a while ago a guy saying he’s 100% sure it’s due to dry skin and static. I tried what he said (using lotion to avoid dry skin) and instantly felt a difference in gameplay.
Dry skin is more prone to holding a static charge so there’s that
Wireless USB hub with wireless kb and mouse as well.
I think you could be on to something about the walls tho.. ngl.
Pointing fans towards the wall seems to lift of the effect of slow inputs in some degree
