Severe Imput Lag.Desync.Hitreg Issues in cs2 Reward offered
kyube
Re: Severe Imput Lag.Desync.Hitreg Issues in cs2 Reward offered
Post by kyube » 27 Jun 2025, 13:42
Dcyker wrote:
25 Jun 2025, 08:26
Sorry if I wasn’t clear enough, I have ASUS utility Off and SMT Control off, other than that I didn’t change anything in BIOS.
Reinstalled Windows after EXPO disabled? Yes
That's good, we can rule out RAM sheningans to some extent if so.
You'd ideally try disable a few of the common variable clock rate settings, which are mentioned in AMD server tuning documentation (check the AM4/AM5 thread in my signature)
Dcyker wrote:
25 Jun 2025, 08:26
I tried 4.7 GHz with Vcore 1.15 Gameplay becomes a little different but usually lasts for 1 reboot then it goes back to being abnormal.
I have Afterburner installed whenever I lock my GPU I tried multiple different Voltages the Hitreg becomes noticeably better but the Enemies also become faster as well again movement wise. It becomes harder to kill them.
I bought a i210-T1, used to play with it but haven’t tried on my current PC could give it another try.
Router Settings I have a FritzBox 7690 I turned everything I can off (IPv6, UPnP, FritzBox Services etc.) Filters I left on.
I am currently using a CAT 8 (Ercielook Lan Cable 5 m, High Speed Cat8 Network Cable for Outdoor and Indoor Use, 40 Gbps Braided Patch Cable with RJ45 Connector for Router/Gaming/Modem) from Amazon to be exact.
I cannot assess whether your CPU is able to sustain 4,7GHz @ 1,15v. You must troubleshoot it with known tools, such as P95 small FFTs, OCCT etc.
The NIC may or may not impact your overall experience, it's low down the list in terms of potential causes.
I've only mentioned it just in case
Dcyker wrote:
25 Jun 2025, 08:26
Could the Audio be an issue? I use Apple Headphones just plugged into my motherboard with a cable to extend the range. I‘ll try to Guides (Valley and yours) and see if I can achieve something
Very slight chance, though I wouldn't bet on it.
In theory, the ALC4080 is worse than previous chipsets in terms of total audio latency & causes DPC/ISR driver overhead.
How noticable it is to you is debatable. I doubt it is the main culprit of your issue.
Dcyker
Post by Dcyker » 28 Jun 2025, 05:58
I‘m going to try the Guides now, I‘ll post an update asap, I tried my I210-T1 and it’s way worse people peek me even faster than it is right now, I sent you a YouTube Link to a Video that shows the same Issue I encounter on a daily base.
fff333
Post by fff333 » 15 Oct 2025, 22:24
Dcyker wrote:
28 Jun 2025, 05:58
Hey bro, any updates/fixes that worked from when you last tried anything? Could you please share the video?
Watchdog
Post by Watchdog » 21 Oct 2025, 12:08
Dcyker wrote:
28 Jun 2025, 05:58
Did you fix it? I have Intel I210-T1 too and people just ferarri peek me but if I see their POV, they had all the time in the world. But in LAN tourna, I completely destroy them.
Sz3ypy
Post by Sz3ypy » 21 Oct 2025, 12:51
Did you try "Play" with network settings ?
CsgoPlayer1337
Post by CsgoPlayer1337 » 21 Oct 2025, 15:53
Hi there, I might have an idea that could help with your network issue. I've been learning MikroTik RouterOS and have been getting great results with it for solving various network problems.
Just to give you some context, I'm from the CIS region and I've already run multiple tests with other gamers here. They all report that the game (or online experience) has become much smoother and more stable after the mikrotik and his settings.
meffercr
Post by meffercr » 24 Oct 2025, 04:05
CsgoPlayer1337 wrote:
21 Oct 2025, 15:53
Hi. I'm also from the CIS and use a Mikrotik Hex, I also have a Hex S. Could you share your settings?
crack
Post by crack » 24 Oct 2025, 22:05
21 Oct 2025, 15:53
Please do share your settings man, I happen to have a MikroTik router as well, RB4011iGS, RouterOS version 7.15.2.
I haven't done much to it besides changing the order of the default ipv4 and ipv6 firewall rules to cut some negligible amount of latency.
CsgoPlayer1337
Post by CsgoPlayer1337 » 25 Oct 2025, 11:39
meffercr wrote:
24 Oct 2025, 04:05
21 Oct 2025, 15:53
Not very active here. For contact details, see my profile.
Trying different queues and bridge settings — already getting some positive outcomes.
SammYrai
Post by SammYrai » 25 Oct 2025, 16:18
I second this I also want the RouterOS settings you have :D I work with mikrotik for 15 years and I have like 10 different mtiks lying around.
