Page 2 of 2
Re: Discord creating CS2 Jitters
Posted: 08 Aug 2025, 17:53
by dsavovic25
Coldplayer wrote: ↑
08 Aug 2025, 11:00
dsavovic25 wrote: ↑
07 Aug 2025, 13:13
I think I fixed it by going back to old Realtek windows driver from 2015. I've disabled Interrupt Modulation, Flow Control and Priority & VLAN which were on by default, and for a half an hour of playing DM i haven't noticed any spikes while discord was connected to the voice chat.. Could be worth a shot if you have REALTEK nic..
Where did you get the realtek driver from? I just had stock windows high definition audio driver because the realtek ones i download from realtek/my motherboard are bloated with realtek crap.
I just uninstalled the current driver I had, Windows installed the old one probably via windows update.. But that is not an audio driver, I've downgraded a ethernet driver.
Posted: 17 Aug 2025, 03:40
by Misha1337
Have you tried limiting discord upload speed using netlimiter ?
Posted: 28 Aug 2025, 02:54
by netborg
Yes, discord may be pretty heavy on system load. I usually close it for serious gaming sessions, and prefer to use Teamspeak which is very lightweight.
I recently have added a percentile view to show the V-Sync buffer in my new VRR low-latency frame pacing mode (dxvk), and Discord as well as Firefox are usually increasing the p95 and p99 percentiles quite significantly (like 100+ microseconds) which causes the mouse to feel a bit laggy.
Posted: 30 Aug 2025, 18:21
by dizelcs
Try debloating Discord with:
Downside of discord-fixer is that keyboard shortcuts stop working.
Also, try putting discord.exe cpu affinity on last 2 cores (check only cpu 12,13,14,15) and cpu priority "below normal" in task manager. If it works, install process lasso to make it permanent, like Chief said few posts earlier.
Posted: 08 Sep 2025, 17:43
by dreakopotamus
Make sure the setting Enable Quality of Service High Packet priority is off. It under voice and video
