Everything about latency. This section is mainly user/consumer discussion. (Peer-reviewed scientific discussion should go in Laboratory section). Tips, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
Sandy
Post
by Sandy » 24 Aug 2025, 00:43
mago wrote: ↑19 Aug 2025, 18:33
maybe it will be beneficial for others to see those differnce
I'll update my question.
I can't track the target correctly on any mouse pad. However, I can track it with zero lag on a wooden table, cardboard, and some fabric sheets.
I found someone else experiencing the exact same problem as me.
https://forums.tomshardware.com/threads ... ag.3659517
amorou
Post
by amorou » 24 Aug 2025, 13:31
Sandy wrote: ↑24 Aug 2025, 00:43
Mouse skates glide on table easily ,or thicker mousepads will hold mouse more and will feel sluggish but precise to flick/stop , you might mistake lag with that
Sandy
Post
by Sandy » 24 Aug 2025, 22:47
amorou wrote: ↑24 Aug 2025, 13:31
No, I rely on evidence to determine if there is input lag. I don't rely on feelings, that's not accurate.
amorou
Post
by amorou » 25 Aug 2025, 04:16
Sandy wrote: ↑24 Aug 2025, 22:47
Do you think you being able to track or not is a evidence ?
Sandy
Post
by Sandy » 25 Aug 2025, 22:14
amorou wrote: ↑25 Aug 2025, 04:16
I took a video and you can check it out. On other surfaces, this delay is completely non-existent. So far, I haven't found a mouse pad with zero delay.
https://www.youtube.com/shorts/lHv6qH_Ud2w
Sandy
Post
by Sandy » 27 Aug 2025, 22:33
A mouse pad has only one purpose, and that is to provide good tracking. I tested the Artisan Ninja FX Zero today and did a lot of testing. I found that this mouse pad has very low input latency. The only drawback is that it is too expensive.
